Old 06-22-2007, 01:01 AM   #1
Ackattack
Ackattack's Avatar
Won't start....need help ASAP!
Ok guys, I need some help and you are all the most knowledgable people I know when it comes to old school chevy engines
So I'm going on a camping trip tomorrow in my motorhome.
Its an 84 454 with a turbo 400. Its got a quadrajet carb on it.
Basically when I hit the start switch sometimes it will crank over, some times it won't. I put a new battery in it, new high torque mini starter, new remote solenoid,and new cables. So everything from the battery to the starter is new. So as long as the starter solenoid gets the switched input it should turn over. Well it doesn't all the time.
So like I said, its an 84, so of course it has miles of vacum hoses. Tonight I popped off the entire air cleaner assembly so that just the carb was there. I tried starting it, and it turned over like it was nothing! Of course it didn't start. I messed around with this hose and that and the carb linkage and finally it fired up. I turned the distributor to advance the timing a little so it would run smoothly and it was fine. I tried starting it up a few more times and it did it fine.
I let it run for a while and then drove a few feet to its parking spot, now it won't turn over again!
I'm thinking it has something to do with the carb, but it seems awfully wierd that the carb could stop the stupid thing from even turning over. But the only carbs I've really messed with is Edelbrocks. I mean I could understand having problems if it was a 13:0:1 454, but this "bad boy" is probably about 8:1.
So like I said I need some suggestions on things to look for or check before I go on vacation.
Derek
Ackattack is offline   Reply With Quote
Old 06-22-2007, 01:08 AM   #2
67 cst swb
67 cst swb's Avatar
Re: Won't start....need help ASAP!
Check for a loose electrical connection, either at the battery or at the solenoid. Sounds to me like an electrical issue, but not a serious one...
The times it won't turn over... Can you jump the terminals on the remote solenoid and it work?
But, I'm no expert. Hopefully someone else will jump in here...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 06-22-2007, 01:10 AM   #3
Ackattack
Ackattack's Avatar
The battery cables and other electrical connections are all tight. I mean I was having the exact same issues with the stock starter without a remote solenoid.
Oh, I also tried to play with the timing to see if that would make it easier to fire up, it didn't really seem to help.
Old 06-22-2007, 01:12 AM   #4
Ackattack
Ackattack's Avatar
Oh yeah. It also has some type of vacum operated valve in the passenger side exhaust manifold. I don't know if this thing works or not, but even if it were closed I don't think it would stop it from turning over.
Old 06-22-2007, 01:16 AM   #5
67 cst swb
67 cst swb's Avatar
I definately think your issue is electrical...
What about the ground wire to the motor?.... clean connection? Solid? That also a NEW cable?
My Trucks:
Old 06-22-2007, 01:17 AM   #6
67 cst swb
67 cst swb's Avatar
The times that it does not turn over, Is there an audible "click" when the starter tries to engage or absolutely nothing?
Do the dash lights do dim or out? is it the same when it turns over as when it does not?
My Trucks:
Old 06-22-2007, 01:21 AM   #7
Ackattack
Ackattack's Avatar
when it doesn't turn over, it actually tries to, maybe turning an 1/8th of a turn in the process before it get's stopped. Its not like a bad solenoid (I've had plenty of issues like that on my 72....so I know it's not that)
I'll have to check the ground cable.....didn't check that.
Old 06-22-2007, 01:24 AM   #8
krue
Designated A-hole!
krue's Avatar
If it won't turn over you have to check a few things...first is battery cables. Good tight, clean connections at the battery and starter/engine. Make sure the cable to the starter isn't grounded to the exhaust manifold (have had that happen to me). Check your ignition switch by checking for 12v at the solenoid when you turn the key to the crank position. You can half-ass check the soleniod by listening to see if it clicks when you hit the key. If it's a solenoid that's on it's way out you can sometimes start it by tapping the solenoid with something when it won't turn over and see if that helps. The only other thing I can think of is taking the starter to a parts store and having them check it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-22-2007, 01:26 AM   #9
motopatzo
motopatzo's Avatar
when yu say it doesn't "turn over", is there any other sound like clicking, or solenoid engaging or a slow starter speed? I am thinking if you have nothing- .....try and run a jumper wire to the S terminal of the starter to check if it will turn over then. It it does turn over with a jumper, could be bad neutreal safety switch, bad wire to starter or bad connection causing a voltage drop.
motopatzo is offline   Reply With Quote
Old 06-22-2007, 01:27 AM   #10
67 cst swb
67 cst swb's Avatar
have someone watch everywhere (underhood, underneath at starter) while cranking (or attempting to crank) hopefully, one of those times it doesn't start it will spark, this will show you if there is a poor ground somewhere...
Also, if it attempts to start(1/8 turn or so) I definately think it's electrical. My only other thought would be the key switch, but not thinking so.... This may sound funny but,... if it's a tilt steering column, be sure it's in the straight position... I've had them up in the highest up-tilted position and had problems before.... also be sure the shift lever is fully in park (above mentioned Nuetral Safety Switch)
My Trucks:
Old 06-22-2007, 01:36 AM   #11
Ackattack
Ackattack's Avatar
Hey thanks for the quick reply guys!!!!
Pretty sure that it is indeed the ground cable. I hooked up a jumper cable from the - battery terminal to the back of the engine as a make shift ground cable (class A motorhome....engine inside ) and it fired up no problem!!!! Over and over without a problem.
So tomorrow I'll replace a few ground cables (frame to battery, frame to engine, and probably add a battery to engine for good measure)
Thanks again guys, you may have saved my vacation!
Old 06-22-2007, 01:34 AM   #12
motopatzo
motopatzo's Avatar
Ok, it is intermittent, and it tries to turn over. Everything else is replaced. I would look at the ground as well. Even if it is tight at the frame or the engine (wherever your conection is) remove it and make sure it is clean and not corroded.
Old 06-22-2007, 01:38 AM   #13
67 cst swb
67 cst swb's Avatar
Whooo-hoo!!!!!!!!!!!!!!!!!!!
Now I can go to bed....
My Trucks:
Old 06-22-2007, 06:56 AM   #14
krue
Designated A-hole!
krue's Avatar
Glad to hear it worked for you.
www.daveramsey.com
Old 06-22-2007, 05:18 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
run that neg cable to the engine its self... not the frame, or alt bracket. You can probably find an open bolt hole on the head or something. Then run a strap from the engine to the frame.
Starting the engine puts a bigger load than everything else on the RV combined. So that is where you need the amps, and you can have all the amps in the world, but, as you've seen, without a good solid clean route back to the battery, the amps don't exist.
Old 06-22-2007, 05:27 PM   #16
truckdude239
truckdude239's Avatar
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-22-2007, 05:45 PM   #17
Ackattack
Ackattack's Avatar
this morning I ran cleaned up the ground cable to the frame, and then added one to the back of the head....starts great now.
