Old 09-17-2002, 09:45 PM   #1
jiggs
poker face
1 1/4 sway bars
what years and models of trucks had 1 1/4 sway bars from the factory? I'm going bone yard shopping. I'm guessing 1 tons and camper specials. What should I expect to pay for one?
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month.
jiggs is offline   Reply With Quote
Old 09-17-2002, 10:03 PM   #2
slam33
slam33's Avatar
Sway bars are cheep, $10. ! 1/4 is going to be hard to find since the stock one is 1 1/16.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-18-2002, 03:13 AM   #3
jiggs
poker face
What about one ton trucks from the mid to late 80's? Are they 1 1/16 too?
Old 09-18-2002, 06:02 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
I too would be interested to know exactly what years fit, which is the best to get and which bits I need to get exactly. I have located a Junkyard in the UK that specialises in breaking American trucks and really want to get a sway bar to fit to my truck.
What is involved in fitting it, do I need to drill mounting holse etc and if so how critical is the placing bearing in mind I don't have anybody else with a truck nearby to look at.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 09-18-2002, 07:23 AM   #5
JJR
JJR's Avatar
I have found them on mid 70's to early 80's 3/4 and 1 ton trucks. Hollanders only goes back to 1979 on sway bars but it shows from 79-91 (88-91 old body style) had 31.75mm (1 1/4") bars being available on trucks.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 09-18-2002, 09:05 AM   #6
1-PU70
1-PU70's Avatar
I got mine from a 71 or 71 3/4 ton Burb with a 402.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 09-18-2002, 10:42 AM   #7
j-dogg
I got a 1 1/4' one from an '84 1 ton dually. Mounts in exactly the same spot as the regular half ton sway bar.
j-dogg is offline   Reply With Quote
Old 09-18-2002, 12:37 PM   #8
BUXMAN66
go bucks!
typically the '60--'87 truck anti-sway bar will work perfectly w/our years trucks.1/2 ton=1 1/16 diam. 3/4 ton= 1 1/4 diam. 1 ton= 1 1/2 diam. one of the biggest modifications you can do to change the handl;ing characteristics of our trucks.
BUXMAN66 is offline   Reply With Quote
Old 09-18-2002, 08:20 PM   #9
Brad
Out of the carpool lane.
Brad's Avatar
I've got a 1-1/4" bar with 3 poly bushings and brackets for $70+shipping, also a 1-1/8" bar with 4 rubber bushings and brackets for $60+shipping.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-18-2002, 08:39 PM   #10
wnc mountain
More hobbies than money!
wnc mountain's Avatar
OK, If my 70 currently does not have a sway bar, will holes have to be drilled, or are there holes from the factory for a bar?
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 09-19-2002, 05:08 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
I've definitely got to source one here in the UK as the shipping costs from over there would be horrendous (I am assuming that they're fairly weighty). Are the brackets bolted or rivetted on originally? Do I need to take a grinder with me to remove them from the donor?
Phil
'67 C10 long fleet.
Old 09-19-2002, 10:59 AM   #12
Kas68c10
Kas68c10's Avatar
I believe there a rivets one the frame where the mounting brackets go. Simply grind them off, bolt on the brackets and sway bar to the brackets. It is really obvious where it has to go and how it lines up once you get a sway bars to look at. Shipping isn't all that bad, they are not all that heavy. Not sure about overseas, never done it. BIG difference in handling.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
