Old 06-24-2007, 09:37 PM   #1
wibilly
wibilly's Avatar
wiper help please
i'm putting my truck back togather. my washer pump does not pump water. are there rebuild kits avalible ? do you get a new pump with a new wiper moter? and if i go with an aftermarket pump which wire powers the pump? is it the dark blue one? thanks a bunch
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-25-2007, 12:36 AM   #2
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Re: wipper help please
I think you missed the correct forum. I will move this over to the pickup forum for you.
As far as your pump is concerned I think you still can get a complete pump or a rebuild kit thru NAPA or Carquest.
Good luck
oldiron forum staff
oldiron is offline   Reply With Quote
Old 06-25-2007, 12:51 AM   #3
SactoJim
SactoJim's Avatar
http://www.truckandcarshop.com/trucks60_72/t60_046.html
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 06-25-2007, 01:20 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
ill have to keep that in mind, mine hasnt worked since i got it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-25-2007, 01:37 AM   #5
wibilly
wibilly's Avatar
thanks for moving this old iron this is where i ment for it to be.i had no idea these were availible. i guess because iv'e seel so many inline in these trucks. probably because it's easier than tearing the dash apart,but mine is already apart so now is the time
Old 06-26-2007, 06:28 AM   #6
HomerJ
HomerJ's Avatar
Re: wiper help please
I have the same problem, but with a twist:
I bought the rebuild kit, only to find that the pump diaphragm was dry-rotted to death. The next logical step was to replace the entire pump assembly, which presented its on set of problems. First, I have a 67, which apparently has a "slightly" different design from 68-72. The pump assembly was about 1/4" longer than the original one (screw holes don't line up). Also, the original "cam" was metal, with the pump rod being nylon. The repro has nylon cam, and a metal pump rod. I can't get the metal cam to come off the wiper motor assembly, which would leave a metal-to-metal contact if I were to find a way to get the new pump to mount.
The only good thing is that I'm tearing the truck down for a resto-mod. I'll probably replace the whole wiper motor assembly in the process.
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73
67 Chevelle SS Clone 454/TH400/3.73
HomerJ is offline   Reply With Quote
