Fix It Till It's Broke
Probably dumb questions but can I get some help?
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
Re: Probably dumb questions but can I get some help?
water temp sender at the thermostat housing, kinda wierd place for one? I'm not sure. Usualy in the head or manifold.
n As far as the one at firewall,???? I can't tell. |
Firewall pic- looks like part of your oil pressure line to the gauge, but you may be missing the line to the back of the block. Are you reading any oil pressure?
Must have been typing at the same time
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-25-2007 at 05:08 PM. |
I agree with the first assesment about the temp sender. The second, you asked what that does. Currently nothing... but if it was hooked up, I'm fairly positive that is for the oil pressure gauge.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 06-25-2007 at 05:05 PM. |
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
awesome..thanks guys...how do i go about replacing the oil pressure line...cause i don't get any readings on the water temp or oil pressure
#7 | |
That's the great thing about this board, no one seems to mind any questions. You may have a faulty temp. transmitter, there are three other locations you can mount that thingy, if you don't like where its at.... J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-25-2007 at 07:30 PM. |
I would guess that the thermostat housing is off of a later model vehicle. That sending unit is more likely to be a computer sensor that tells it when the engine has "warmed up" because the thermostat has opened. There would probably have been another in the "normal" place in the head, that would have been connected to the gauge/idiot light.
#9 | |
It's the air up here
The oil line would have to be going to a mechanical gauge inside the cab, not an electronic one, right? Oh and I agree on the bracket bolt.... get one in there.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
Oil line kit available at most good speed shops. (NOT AUTO-ZONE,NAPA, ETC....)
Or summit/jegs. |
Does that mean that Summit or Jegs has em???
so what should i do...get a oil line kit and a new thermostat housing?
You can leave that housing, If you don't mind installing an aftermarket gauge pod with water temp,oil pressure and volt meter, all the necessary fittings will be in the kit. I bought one from the local parts store. My temp sending unit is in the driverside head, up towards the front. Use teflon tape on it when you put it in, same for the oil pressure sender.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#15 |
thanks...i'm going to have to try that...just one of those aftermarket ones that mounts to the underside of the dash right? or should i buy the individual guages and mount them in the gauge cluster?
#16 |
![]() Join Date: Aug 2005
I got a new oil line for the gauge at NAPA. Had to use an adapter fitting at the block though.
