Old 06-27-2007, 10:16 PM   #1
indyracer
indyracer's Avatar
This is not the direction I wanted to go...
Since I discovered that 2 cylinders have low compression and 1 has zero compression, I started tearing down this motor for removal. I will be building another 350 to drop in. I have the block, crank and heads back from the machine shop. Really I've had it all since last fall. So this weekend I am going to get started. I can't promise how quickly it will come together, but hopefully all goes well. Wish me luck
Cheers,
Tony
A day without sunshine is like, you know, night.
1970 Chevy CST10 (Green)
2005 Silverado Z71
2000 Pontiac Bonneville
indyracer is offline   Reply With Quote
Old 06-27-2007, 10:23 PM   #2
68chevy68
68chevy68's Avatar
Re: This is not the direction I wanted to go...
I went to freshen mine up here a while back and found a nice big crack in my block. I got another one though. Good luck with your build.
68chevy68 is offline   Reply With Quote
Old 06-27-2007, 10:24 PM   #3
eedgell
It's the air up here
eedgell's Avatar
Looks like a ton of fun!!! I love making them new again. Good luck with the build!!!
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-28-2007, 06:46 PM   #4
84_4x4
84_4x4's Avatar
i just went through the same thing and a tip would be pull the motor out before doing work it makes things alot simpler
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 06-28-2007, 07:33 PM   #5
randomhero472
randomhero472's Avatar
on a scale of 1-10 how hard is it to rebuild one of these yourself... and any special tools you need? thanks
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-29-2007, 01:55 AM   #6
jkeady
jkeady's Avatar
It depends on how much you want to do. The ones I've built, I had the machine shop install the cam bearings (simply because it's a PITA), install the rings on the pistons and the pistons on the rods, and install the freeze plugs, and I did the rest (aside from the actual machine work.) A ring compressor and a valve spring compressor are about the only tools I remember buying for the purpose of engine work.
It's not as if there's any really intricate, difficult steps, just a lot of little things to keep track of. Biggies are to keep everything nice and clean, take your time, and have a plan. Probably for your first time out, you'd want to find a good book to help guide you, plus you get torque sequences/specs, and helpful reference stuff like that.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 06-29-2007, 02:10 AM   #7
Random Guy
Random Guy's Avatar
I am actually considering this on my 307. Is there any books you would recommend for it?
CARPE CERVASIUM!
1968 C10 Fleetside LWB
Remember Cthulu is watching you!
Random Guy is offline   Reply With Quote
Old 06-29-2007, 05:21 AM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
damn that sucks man but atlest itll be more fun to drive once you get it done with a bit more pep im sure
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-29-2007, 07:58 AM   #9
larry may
Smile Re: This is not the direction I wanted to go...
I believe Billa posted a list of every tool possibly needed for a project of building an engine. The list may be in FAQ. Have fun
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
