06-28-2007, 11:19 PM | #1 |
Chevyrestoguy's '55 build
I've been a member for awhile, and I figured that it was time to post some shots of the truck. It's a '59 with '55 front sheetmetal. I've had it for 14 years, and for most of that it sat dormant due to buying and remodeling a house, starting a family, and 50+ hour workweeks. I did the chassis back in '94 (Camaro clip, boxed rails, step-notch, Ford 9"). I have been hearing it from my buddies for years about how it just sits in the garage, but for the last 6 months, I've been back on it solid. It's been good for me, as I'm finally back to being excited about hotrods again. I got so caught up in the work and family (which is good), but I needed to do something for ME. I do all of my own work because I'm a cheapskate and I refuse to pay huge shop labor charges. Here's some pictures, I hope you like 'em.
________ Digital scales Last edited by chevyrestoguy; 02-18-2011 at 11:11 AM. |
06-29-2007, 12:44 AM | #3 |
Certified Car Nut
Re: What I've been working on....
Pretty nice work you are doing there. Its not being cheap when you can do the work just as good or better than most body shops. Plus no one cares about your ride as much as you. So good luck with it
06-29-2007, 12:51 AM | #4 |
KEEP ON TRUCKIN'
What you are doing and have done looks great! Keep it up.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
06-29-2007, 07:25 AM | #5 |
Yellow truck club
Lookin' good ...
Brian ..
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
06-29-2007, 11:41 AM | #6 |
Thanks for the comments, guys. I wasn't in the typing mood yesterday, so I'll tell a little bit about what I've done so far and what I've got planned. To date, I've done:
Chassis: I grafted a '71 Camaro clip and boxed the entire frame from front to back with 3/16" plate. I built an 8" step-notch in the rear,so there's plenty of room for the rearend to travel. The rear is a Ford 9" out of a 1978 Lincoln Versailles, which I had narrowed by Currie Enterprises. The center section is a 3.70 Trac-Loc with 31 spline axles. The rear housing brace was built by me. The gas tank is a '55 Chevy car unit and is located behind the rearend. The wheels are 15x6 in the front and 15x10 in the rear. The rear wheels have an interesting history. They are magnesium (1963 vintage) and were one of the original sets on the Greer, Black, and Prudhomme Top Fueler. They later went to a different rear axle, which made the bolt pattern on my set useless for their set-up. I bought them in 1993, before the big Torq-Thrust craze. Body: I bought it from my neighbor in 1993. It was originally an Alta Dena, California School District work truck. It has zero rust. It was hot-rodded when I bought it. The previous owner swapped the front sheetmetal to the '55 style. Before I got it, it had a 396 (gone), 4-speed (gone) and an early '60s Old rearend. I was told the previous owner street raced it, and looking at how he butchered the floor and the bedsides, I believe it. I had the hood louvered (68 louvers), and welded all the trim holes shut. I shaved the front marker lights and now have a '57 Chevy grille bar as the center grille. I have modified the headlight rings to resemble a '57s, but I still need to do some work on them. The front bumper is a 3-piece bumper from a '55 Nomad I bought off of ebay. I still need to build bumper mounts and a front valence to fill the void between the bumper and the front sheetmetal. Engine: I'm in the mock-up stages now, but it's a 454/TH400. The picture with the tunnel ram is only a mock-up to see if I have hood clearance (I do!), and if you notice, it's one of my small block manifolds. The headers are Hedmans (2" primaries/3.5" collectors) from a 67-69 Camaro. Firewall: I got tired of welding holes in the stock firewall (I counted 68(!) holes), so I decided to build my own. Plus, with the stock firewall, the passenger side valve cover is real close to hitting it. So I cut out the stock firewall, but I left 1.5" all the way around to give the new panel some rigidity. The firewall is made from .063 sheet metal. The setback is 3.5" deep for adequate distributor clearance. The entire panel was glued in place with a badass aerospace adhesive designed for bonding wing skins together. For added insurance, I spot welded the backside every 3". Due to the subframe being installed high in relation to the stock chassis, the transmission actually sat higher than the stock floor, so I had to build a cover. I like the idea of having a removeable cover, so I utilized the factory hole and built a new panel with .080 for the base and .063 for the sides. I utilized Nut-Serts and button head Allen fasteners for the attach fasteners. Whats next: 1: Mount the column 2: Fix a hole in the floor done by the previous owner 3: Smooth the dash 4: Mount the seat 5: Figure out a shifter (probably Lokar) 6: Pull the cab off and detail bottom and final paint/reinstall 7: Respray the chassis and the list just keeps going........................... Last edited by chevyrestoguy; 09-01-2011 at 03:20 PM. |
06-29-2007, 04:23 PM | #7 | |
Tripple Five Fanatic
Nice. Last edited by Tri5Nerd; 06-29-2007 at 04:24 PM. |
06-29-2007, 05:22 PM | #8 |
Solidaxel- I work in aerospace, and through the years I have accumulated a fair amount of sheetmetal tools. I'm always shopping for more, but the ones I want take up alot of shop space (shrinker/stretcher, english wheel, brake and shear). I basically use my bandsaw, an upright 3" belt sander, bench grinder, 100 amp mig welder, 175 amp mig welder, and straight and angle grinders. If I need a shear or a brake, I call one of my buddies who owns a shop that build racecars and use his. I really enjoy doing metal work.
Tri5Nerd- The grille bar has taken alot of time to fit right, although it doesn't look it. The width of the bar is actually about 2" wider than the grille opening, so the original '55 grille outer shell has cut-outs on each side to account for that. The backside of the bar has 1/4" attach studs about 8" apart, and the end studs go through the apron of the fenders and are attached with nuts on the backside. I still have to attach the other studs, and I may use internally threaded rods because the grille bar has a peak and the space behind it is about 3-5" and the factory studs are 1.5" long. Another thing to note is that the bar is made of potmetal and cannot be welded. Last edited by chevyrestoguy; 09-01-2011 at 03:21 PM. |
06-29-2007, 11:45 AM | #9 |
Nice touch on the grill and front bumper. I like the firewall and trans cover, do you have sheet metal tools or like the rest of just a 6" vise!!!
06-29-2007, 12:31 PM | #10 |
It is nice to get "Guy Time" . I completely understand about time to yourself. The truck I am working on now is my dad's and we are finally getting back on it after what seems like 25 years...lol. With kids it is hard to get enough time to work on projects. It is looking great and soon enough you will have it driving again. Good luck and keep posting pictures.
Bernie |
06-30-2007, 12:25 AM | #11 |
looks pretty nice man!!!!
07-04-2007, 12:56 AM | #12 |
I love it! Nice stance, especially with those fat meats in the back. Glad to hear your back to it.......keep it up....and don't forget about your camera. We loves pics and your work is easy to look at
07-04-2007, 02:33 AM | #13 |
Nice project you have. I really like the 57 Chevy grill thing you did and the 55 bumper look's great. Keep those progress picture coming.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
07-04-2007, 03:18 AM | #14 |
Designated A-hole!
Love the work you've done to it, gonna be badass when you're done.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-06-2007, 11:23 PM | #15 |
Alex, trucks looking good! In the process of grafting in my sub frame........
07-13-2007, 11:33 AM | #16 |
Very nice workmanship. I like the grill too!
07-13-2007, 03:42 PM | #17 |
The next project to attack is this ugly hole in the floor that the previous owner hacked up to install a 4-speed shifter. I could make a new piece from scratch, but I figure that getting one from a donor cab would be the better way to go. Does anybody here on the site have a junk cab that they would be willing to sell me the section I need? If so, I'm interested. I've looked all over my area for a cab in the wrecking yards, but the oldest one I could find was a '67.
Alex Last edited by chevyrestoguy; 09-01-2011 at 03:21 PM. |
07-13-2007, 04:56 PM | #18 |
polishing a turd
let me see if that spot is still good on my junk cab.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
07-13-2007, 11:24 PM | #19 |
I really appreciate you checkin' for it!
07-15-2007, 12:50 PM | #20 |
The column parts finally arrived, so I got to work. The column I have was a freebie, and being a low-buck guy, I decided to run with it. It's a GM column, and I believe that it's from a 67-72 GM truck. It's non-tilt, no keys, and it has a very clean simple look to it. I measured it, and the diameter was 2". Great, I thought, and ebayed a 2.5" drop and a Billet Specialities floor mount, all for a 2" column. I get the parts, and attempted to mock-up them up only to find that GM had crimped the column tube in a few places for reasons that must have been for it's original application. Just my luck, the area that I initially measured was about the only area on the column that was truly 2". I completely disassembled the column and cut off the end of the tube where the turn signal fairing attaches. I got a 30" section of mild steel 2" .065 wall from the scrap bin of the local steel yard ($4 total) and welded the end to it. I even Scotch-Brited it with some WD-40 for a trick look and sandblasted the fairing. It'll all get painted eventually, but it looks cool for now. Now the 2" column parts fit perfectly, so it was time to mock it up and determine where the hole in the floor was to go. Once I got it where I liked it, I drilled the 2" hole. I still have to cut the steering shaft to it's final length and install the u-joints. I'll probably do that today. I also need to make a drill template for the lower column mount because it's held to the floor with 3 allen-heads that secure from the engine side. Gotta keep knocking these little projects out! Next project....Gas pedal
01-03-2008, 08:20 AM | #21 |
i like the guage-in-the-dash trick. i found these on ebay. ck 'em out! number 140187981768. plus--i love the way you deleted those stupid parking lights under the headlights!
i'll be doing the same/steve |
01-05-2008, 07:57 AM | #22 |
Very nice ride.
07-15-2007, 01:12 PM | #23 |
Nice job on the column! At first I thought it was a flamming river stainless column.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 07-15-2007 at 01:13 PM. |
07-16-2007, 06:20 PM | #24 |
Certified Car Nut
Very nice work keep the pics coming.
07-18-2007, 03:00 AM | #25 |
thats a really nice truck. i like it alot. i got a question: how hard was it to put that bumper on?i know u said u have to make mounts, but did it just fit into place or did u have to persuade it? i like that idea, and my friend has a spare bumper like that, and i would like to do it to my truck maybe.
