06-30-2007, 10:02 PM | #1 |
Rear Glass Removal
Hey all,
I was wondering what all is entailed to remove the back window off a 72? I would like to pop the glass out, add window tint the reinstall with molding covering the the area where the tint was cut. If it's a hassle then I'll try tinting the hard way. Thanks |
06-30-2007, 11:11 PM | #2 | |
Son Of Gravel Man
Re: Rear Glass Removal
I used a peice of string and a flat head screwdriver to get my slider out and cause im cheap (broke) I used the same gasket to put the solid one back in. It was pretty easy and havent had a problem with it.
Daily driven 70 C10 longbed Its a work in progress Quote:
06-30-2007, 11:35 PM | #3 |
Active Member
shouldnt be any problem re using the Old rubber as long as it still in good usable shape not old a crusty .
07-01-2007, 12:46 AM | #4 |
Designated A-hole!
Just be careful and go easy and you should be alright.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-01-2007, 08:39 AM | #5 |
Crew Cut
about 5 yrs ago i found out the easy way is a gas weed eater by your drive way and small rock.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
