Would it hurt...
Would it be alright to put the sm465/rockwell in the frame now without the motor in or should I wait till the motor is ready and then install it all? If I do put the 465/Rockwell in should I support the front of the transmission with something or will the t-case being bolted down to the torque bracket and then the 2 bolts through the crossmember be enough? I'm trying to get the shop cleaned out and the old rockwell and 465 are taking up room.So,I thought why not put them in now and get them out of the way.I decided against swapping the 205 in,dont want any more transmissions and transfer cases taking up room and what I have is going to be used..
Re: Would it hurt...
Dustin, when I pulled the old 350 to put in the 454 I left the 465 and rockwell in place. With the T-case bolts to frame and 465 0n the crossmember it seemed to remain very solid. I worked well for me. Motor was out for about a month.
both drive shafts were out.
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid ![]() |
Yeah,put it in.Motors come out all the time and no one touches the trans or transfer case.It`s the other way around that takes putting support under the back of the engine when a trans is removed.I never do this stuff as a unit.I install each component individually.I can`t imagine my engine hoist supporting an engine/trans/t-case.
Aluminum slot wheels rule...
Yeah it'll be fine. My tranny and t-case have been hanging for a month already, just bolted to the crossmember, and no issues yet.
Ok,So I think Im going to put them in.Another question...Does the rockwell/sm465 mount using the same bolts thread,size,and length wise as the 205?
1/2" bolts on both... 3.5-4" on the tranny I think and shorter on the torque arm....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#7 | |
Bloo
mine sit unsupported for over a year-- 71 K20 with SM465/NP205, with both driveshafts in.. even moved it around a couple times like that (if you look closely you can see the bellhousing in this pic)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
I reused my bolts from the rockwell with the 205 with no problems.
