2wd to 4wd 70 Chevy C30 frame
Ok, I've done a fair bit of research.
I have access to two 4wd frames: One is a 72 K20... the other is a 91 K5. Are the front spring hangers any different between the two? I plan to use a set of 4wd hangers on the C30 chassis: the question is, which ones? 91 K5 or 72 K20? Last edited by FormerMember; 07-02-2007 at 05:28 PM. |
Re: 2wd to 4wd 70 Chevy C30 frame
The K5 is IFS isn't it? If so, then I would say the lack of front hangers would be a bit different than the '72.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
The '91 probably has wider springs than the '71, otherwise the front hangers will be very similar. The '91 also uses longer front springs so the rear hanger and shackle on the front spring will be farther back than on the '71.
Tim |
![]() Join Date: May 2003
Did you go get the C30 frame yet ????
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Heh, nope
I decided to go with one of these:
This allows me to run a longer spring that will provide a better ride with 4" of lift. |
It's the air up here
Cool! where did you get that? What is it called, make mod.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
#9 | |
http://diy4x.com/suspension.htm
FGB52 = First Gen Beyond 52's It's easier than doing it myself or converting K20 brackets to fit the 1 ton frame. a 52" spring's going to be a better way to go on this rig. Quote:
71 and earlier springs are a half inch narrower, that I can tell? Last edited by FormerMember; 07-04-2007 at 05:00 PM. |
![]() Join Date: Feb 2000
That's an impressive spring hanger!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
