Old 09-21-2002, 12:10 AM   #1
427tom
Longhorn Bed Liner
I guess I'm dreaming. Huh?
Does anyone make one?
I tried hot-air thermal welding bed liner material and it can't be done. (If you could weld liners, you could get 2 and splice the liner just like they did the bed.)
Thanks in advance
Tom
427tom is offline   Reply With Quote
Old 09-21-2002, 07:30 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have one in the back of mine...not that it fits or anything...
They don't make them.
Old 09-21-2002, 02:12 PM   #3
427tom
Seriously, I am still looking into plastic welding bed liner material.
If I could do this, the problem would be solved.
I tried a hot air torche and it would not penetrate the heat thru the plastic section.
I believe there are blade type plastic welders that are not totally unlike soldering irons.
I am going to call Custom and ask them about welding.
Also, I seem to recall that there is a Ford that has an 8'5" long liner. Who knows, it might be possible to fit a brand-x liner in there.
Old 09-21-2002, 02:13 PM   #4
427tom
I wonder if a bed liner company might consider a limited run of Longhord liners?
Do you think they would sell in any sizeable numbers?
Tom
Old 09-21-2002, 04:22 PM   #5
tom hand
CCRider
tom hand's Avatar
If you were going to do that I would just overlap them. Maybe stick them together with silicone. A clean cut edge would look better than any kind of "weld".
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-21-2002, 06:03 PM   #6
427tom
If the material welds, the weld, I think, would look nicer than a lap joint.
I really would want the joint to be water proof.
I suppose an overlap of 4" could be caulked real good and some sort of rivets of countersunk heads bolts could be used to clamp the joint together.
I do confess, I have a hatred for things that overlap - especially repair panels!
Who do you think is the biggest bed liner company?
Tom
Old 09-21-2002, 06:16 PM   #7
427tom
Actually, sprayed on bed liners are about 1/4" thick.
There is no reason you couldn't take a bed, smooth up the contact surface with vinyl tape and use it as a mold for a spray liner.
I have handled the spray liner materials and they are as robust as an actual liner.
In fact, the 1/4" sprayed on liner might actually be too stiff to remove. (!)
Tom
