07-13-2007, 10:20 PM | #1 |
need help with rocker panel
in need of some big time help with my rocker panel i cant get it line up or fit
07-13-2007, 10:41 PM | #2 |
Re: need help with rocker panel
where is it not fitting? did you remove ALL of the old one or part of it?
When I did mine I got the gap at the floor lined up and taced in and started working on the gap under the door. If you close the door you can use a small piece of wood to adjust the rocker for a clean door gap. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
07-14-2007, 12:29 AM | #3 |
Post pics of what you are trying to do.
07-14-2007, 11:12 AM | #4 |
sick69 the old one is all gone its not going over that littl step in the floor and not lining up with the bottom of the cab corner
07-14-2007, 11:52 AM | #5 |
PROJECT 7DEUCE
pics would help us help u
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-14-2007, 11:57 AM | #6 |
ok will go get some
07-14-2007, 03:59 PM | #7 |
PROJECT 7DEUCE
BTW i SHOULD BE GETTING TO MY ROCKER REPLACEMNET THIS AFTERNOON SO iM SURE i COULD HELP YA... DAMN CAPS LOK
07-14-2007, 05:18 PM | #8 | |||
Union Electrician
You need to shape it to fit(hammer and dolly), you cannot just put them on and line right up. Even NOS rockers need a little persuasion(sp) I found that on both my repop rockers that they needed to be reshaped at the cab corners due to poor stamping, but with a little help form the old hameer and dolly things shaped up fairly quick.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
07-14-2007, 06:06 PM | #9 |
yea its coming around i got the back now the front im still having a problem with the post and door frame it hits the cab the window frame that is its start at 1/2 inch at the bottom whrer it meets the cowl and touches at the top
thanks everyone i love this site like everyone says well worth the 25.00 jeff |
