Questionable
been asked a thousand times
and i can't seem to find one
![]() can you use a '68 crossmember with '72 arms, coils, spindles, discs, etc? or will it not work? both are from half ton.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Tightwad
Re: been asked a thousand times
I don't see why not shifty...........I would think that you can......
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
Son of a gun
Shifty, yeah it'll work fine. You will have to fab or find brake lines and use ball joints for the year of the spindles. You will also need the entire tie-rod from the newer truck (ends are different thread and the studs are bigger.) And you have to trim the steering stop on the new spindle (leave about 1/2 inch of it.) I swapped 72 disc spindles into my 69:
Bill BEATERS ARE NEATER |
#4 | |
Use the required tie rods for whatever spindles you use.
Yes. That is exactly what i'm doing to mine. Changing ball joints and tie rod ends. Very easy swap
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
