![]() Join Date: Nov 2002
I'm in the process of upgrading my rearend (hold the jokes please
![]() Seriously. First the background: I have the stock '67 12 bolt non-posi truck rearend equipped with 4.10 gears. I already have the 5-lug axles from Early Classics and am eagerly awaiting the arrival of the caliper brackets from glock35ipsc to mount Impala SS rear discs and Camaro calipers. My intention is to race this truck every once in a while, and MAYBE put some nitrous to it. Not a lot, no more than a 125-150 shot. More than anything, it will be street truck that I take down to the local SCCA-affiliated SOLO events, but no real competition there. I just want to see what I've set-up will do. I have a Gear Vendors under/overdrive to install behind the tranny. The yoke for it uses the 1350-series U-joint. So, I know I'll need a new drive shaft. So, starting at the front of the rearend (rear yoke), I'll need a good strong rear yoke - preferably also using the 1350-series U-joint. But which one? I want to install a "posi" differential. I've had my eye on the Eaton 19556-010 for 4-series. I like the fact that they're rebuildable (where Auburn's cone-drive, for instance, isn't). But I've also taken a hard look at the Detroit Locker. So, which one? The notoriously noisy, yet virtually indestructible (and a bit more expensive) Detroit Locker or the tamer and more street oriented, but still tough Eaton unit? Now, how about gears? I prefer 3.73s over the 4.10s that I currently have. The difference (by my calculations) on the drag strip won't be very much. Day-to-day driving, however, would be much better with the 3.73s (lower revs on the interstate by over 500 RPMs). But what brand? Richmond Gear, Yukon, what? I'm looking for input from some of you guys that have actually used some of the parts I've mentioned, but I'll take directions to somebody that can help. Thanks in advance, Jeff aka TruckSTR
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
Re: Upgrading the 12-bolt Truck rearend - help?
I have a 540cu backed by a TH400 W/gearvendors to a 12bolt with 1350 yokes. I use the EATON posi with a 4.11 gear. It is the perfect set up! Call any decent rear end shop for an Eaton and the correct yoke for that 12 bolt and you'll be set. Good luck!
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#3 | |
What brand of ring and pinion are you using? Cool set-up! How do you like your GV? I can't wait to get my truck back on the road all set up with the GV.
I have an eaton posi in my 72 GMC....has worked great on the street and at the strip. I also upgraded to a 1350 series yoke on the rearend. I think it was a dana piece I got of ebay..but can't be for sure.
I'm also into 4 wheeling and several people I know have Detroit Lockers in their Jeeps (Mine has a ARB selectable locker btw). For jeeps the Detroit works OK on the street as the Large tires, low power have minimal effect. For a street vehicle, especially if you're going to autocross there is no way I would want a locker. I think you'll be tearing up tires and causeing a lot of extra stress on the axles during street driving. My vote is eaton limited slip! |
#5 | |
I've heard similar comments to yours about the Detroit Locker. Tires are going to be expensive enough as it is. ![]()
#6 | |
PorterBuilt Man Crush
![]() Join Date: Jul 2007
#7 | |
I've thought about a 9" Ford rearend. I need something that's bolt-in, reasonably priced, has the right gears (3.73), "posi" and 5 on 5" bolt pattern. If I could get all of that in a 9" Ford rearend for $400 (or even a bit more), then I'd probably do it. Is that what you have? I did a quick once over of the Peyton Performance website and didn't see what I was looking for. If I do it, then I'll have some 12-bolt EC 5 on 5" truck axles and a set of glock35ipsc's Camaro caliper brackets for sale. Oh, well. ![]()
#8 | |
Im going with an eaton but I need gears tooo
Active Member
2K for the 9" - make sure it includes all of your brake hardware - if not tack on another 5-7 hundred. Make sure they include the pan hard bar mount - in my searchs for a 9" that was a common item that was overlooked and added another couple hundred. The 9" is the more bullet proof way to go but I could not justfy the difference in my pricing.
I have about 1200 in my 12bolt with an Eaton posi, richmond 4:10 gears, moser axles, studs & pinion. That included set up labor, SST brake lines, chrome rearend cover etc.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#11 | |
