07-20-2007, 01:22 PM | #1 |
5 inch rear drop question
without lowering blocks i have less than an inch from the bump stop. did yall cut off the bump stop?
07-20-2007, 01:54 PM | #2 |
Worthless
Re: 5 inch rear drop question
I have 5 inch drop springs on mine,I left the bump stops and do not bottom out but I do not carry a load in mine!!!!
07-20-2007, 02:03 PM | #3 |
I have a 6" drop and I cut mine down.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
07-20-2007, 03:44 PM | #4 |
On the road
I have a 4/6 drop and had to cut mine down as well.
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
07-20-2007, 08:05 PM | #5 |
Nice truck, I like the stance & the rake. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 07-20-2007 at 08:06 PM. |
07-20-2007, 04:35 PM | #6 |
I have a 4" in mine and everytime i put a load on it it drops but doesn't hit the bump stops. I am thinking about bagging the rear. I am installing a rear fuel cell and i don't know if the rear spring will sag if I put a load on it with the fuel cell. bagging the rear should prevent it.
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
07-20-2007, 04:51 PM | #7 |
yes.. .putting the gas tank in the rear plays a part... esp. with a full 25 gals.
with a 6in drop in the rear the bump stops need to be cut..otherwise its a jolt to go over railroad x-ings
