Old 07-21-2007, 10:38 AM   #1
67 cst swb
67 cst swb's Avatar
Radiator HELPFUL info
If you need to know what you have or need. Here's some helpful info.
Measure the depth (front to back) of the radiator area that fits into the saddle. It is either 2-3/4" or 3-1/2", you'll also need to verify which saddles you have... measure the indention in the rubble piece in the saddles/mounts. they should be approximately the same measurements as above.
The radiator for an A/C truck is no different than non A/C, other than an A/C radiator is always a 4-row, that requires 4-row saddles (bottom) and 4-row hold-downs (top) they are the 3-1/2" long at the rubber mount, as opposed to 2-3/4" of the 2 & 3 row radiators. Although you can run this 4-row Radiator anytime extra cooling is needed (Big Block also had the same 4-row radiator stock.
Now, If your running A/C, The A/C lines run thru the radiator support, and there are pre-drilled holes for the lines (or maybe could be drilled) and the A/C condensor mounts in front of the radiator and in front of the support (on the grille side)
The only other variation from this is the 6-cyl radiator, it's narrower. Only about 26-3/8" wide, measuring only the core width, it's a 2-row core. All V-8's, whether its a 2-row, 3-row, or a 4-row are all 28-3/8" core width. But, if your going from a 6-cyl to a V-8, you just need to relocate your saddles and top mounts on the passenger side out to the next set of holes on the radiator support. and use a 28-3/8" core width radiator. Either a 2,3, or 4-row of your choice.
Although some people don't have a fan shroud and it works fine, I recommend a factory or aftermarket fan shroud. It creates a tunnel that the air is pulled thru, Air flow is a large part of the equation in cooling. So, use a fan shroud if possible. no, I don't sell them. Sorry.
Ok, that's enough Blah-blah-blah....
PM or call me at 605-341-6634 M-F 8-5 MT with any questions.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 07-21-2007, 05:27 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Re: Radiator HELPFUL info
subscribed as I'll be needing that later on
WRMZ71 is offline   Reply With Quote
Old 06-05-2009, 12:35 AM   #3
67 cst swb
67 cst swb's Avatar
Update... If you have any questions... DO NOT CALL the above number. I'm not there any more... Now he's a 1 man shop & would be slightly bothered by giving out free info.
So... Call me at W-605-348-3850 or Cell-605-381-5430 M-F 9am-6pm MT
Thanks...
My Trucks:
Old 07-26-2013, 01:32 PM   #4
67 cst swb
67 cst swb's Avatar
Ok, another update... Im not at that above number anymore either...
call me at 605-381-5430, if needed... or email me (preferred) at:
bryan6772@gmail.com
My Trucks:
Old 07-26-2013, 03:30 PM   #5
In The Ten Ring
But the radiator core support is the same right? Only the radiator and brackets change from 2 to 3 or 4 row?
Fan shroud huh? Thanks! I may look into one of those. While I am fixing mine up I might as well do the best fix up job I can.
In The Ten Ring is offline   Reply With Quote
Old 07-26-2013, 07:16 PM   #6
Tillik
Tillik's Avatar
I have a 2 core radiator with a factory shroud. This weekend I'm going to drop a 4 Core in. I have the Correct Upper and lower brackets/rubbers.
Will my current shroud bolt up on the bottom? seems like ill be spacing it out with the bigger radiator and there will be a gap. Guessing I could just use spacers on the bottom to take up the gap.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
