Old 07-21-2007, 10:12 PM   #1
hyde
hyde's Avatar
LSX engine mounts
Who makes the best ones? I want to slide the motor back an inch or two...Who builds those that slide the motor back? Thanks Guys for the help
06 Crew Cab GMC[/B] on 22's
07 Duramax 4x4 Lifted Maxed Out!
1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad!
1967 Short and Wide. Soon to be an LS1 and bagged
hyde is offline   Reply With Quote
Old 07-21-2007, 10:46 PM   #2
shifty
Questionable
shifty's Avatar
Re: LSX engine mounts
Go with the plates, then. Don't go with the ECE mounts, they will put the engine a decent bit forward in the engine bay. There are any number of places that sell the plates, including S&P. All of em are about the same damned thing.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-22-2007, 03:48 AM   #3
Sicmaro
Always wrenching!!
Sicmaro's Avatar
with the plates can you use the orignal frame mounts? just bolt the plates to the motor then the mount to that? using a 4l60e will the trans fit the cross member or will it need to be modded? are th350 and 4l60e yokes the same spline? thanks in advance!!!
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 07-22-2007, 04:16 AM   #4
lazybra1n
lazybra1n's Avatar
When I did mine I used the Advanced Adapters plates and then replaced the stock perches with the tubular type-got mine from Brothers, but i've seen them from others also. They adapt to a passenger car type mount where the Motor mount bolt runs longitudnialy (sp?)- front to back- instead of coming in from the back of the stock perch. I then used some poly mounts from Energy. I did have to drill new mounting holes about 3/4-1" back from the stock location because the pan was hitting the x-member (LS1 out of a 2000 camaro). Theres a pic of the L&R below if that helps... For the tranny I was able to use the stock x-member- just redrilled holes in the frame a little farther back and used another poly mount from Energy. I dont have any pic's but I think it was an inch or so farther back. The stock shift linkage looked like it would have worked also, but it was worn pretty bad so I replaced it w/ some Lokar linkage. Hope this helps... Good luck!
'08 VW GTI- daily driver
'74 CJ5 in pieces (4-bolt sb406/700R4 & 3/4ton running gear)
'70 C10 W/ LS1 & 4L60E
lazybra1n is offline   Reply With Quote
Old 07-22-2007, 05:35 PM   #5
shifty
Questionable
shifty's Avatar
That covers most of it. To answer your spline questions read this: http://67-72chevytrucks.com/vboard/s...=700r4+splines
You can use the stock automatic tranny crossmember (NOT the 3spd one!!) and it is nearly a direct bolt up. You may need to drill new holes in the stock mount to bolt up, depending on which mount you use (or maybe for all mounts).
I suggest going aftermarket for the crossmember. If I had my choice to do it again, I would use CPP's tubular tranny crossmember, it is much easier to install than ECE's.
Old 07-22-2007, 09:41 PM   #6
Sicmaro
Always wrenching!!
Sicmaro's Avatar
thanks for the info!!! im trying to do my cheap. i dont have a prob doing a lil fab. would the stock mounts work with the block side adapter plate? or do u need to change to the tubular style? the cross member ill just move and drill as need be. i just want to drop the 5.3/4l60 in without havin to change drivelines. i spent all my money on my camaro haha!!! so cheap is the plan for this!
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 07-20-2008, 03:11 PM   #7
Ford Assassin
Ford Assassin's Avatar
Digging up an old post, but I am wondering the same thing. Although I think he meant stock SBC frame engine towers. Anyone have any idea if the tubular pieces are required with the adapter plates?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-20-2008, 04:49 PM   #8
Sicmaro
Always wrenching!!
Sicmaro's Avatar
i ended up moding the passenger side mount to allow the stock exhaust manifold to clear. I am having to change them out to the tubular frame side mounts now since im adding a/c.......
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 07-22-2007, 11:19 PM   #9
shifty
Questionable
shifty's Avatar
If you want to go cheap, check this post:
http://www.ls1tech.com/forums/showpo...46&postcount=5
See the third links for 68fleetsidec20's budget buildup thread using stock gas tank. I'm tellin' ya, check out all of the links, you'll get a LOT of ideas about what other people are using and you can price out from there
