Old 07-23-2007, 01:55 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Wink 2wd lift kits??
I have a '71 3/4 ton 2wd that I would like to lift high enough to clear some 33 inch tires I acquired. I know I've seen some info on this subject before, but I was unable to locate it. My truck sets good now with the stock suspension and the 33 inch tires and wheels bolt on fine but they rub in the front when I try and turn. I have some brand new 1 ton front coil springs from another project that I haven't used still in the box, but I didn't know if they would lift it high enough and I only want to do this once. Any help would be appreciated. Thanks
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 07-23-2007, 01:59 PM   #2
1969k10stepside
Re: 2wd lift kits??
The 2wd lift kits from the front of a 73+ will work..if you want to lift the rear too...if its a leaf spring truck add some blocks under it like you would on a 4wd.Dont know what to do to obtain that lift on a coil spring truck.You could also add a body lift but they make the truck look crappy,IMO.
Another route is to trim the bottom of the fenders off.Us 4wd owners have been doing that for years...
I dont know how much the one ton springs will lift but its probably not enough to clear 33s with no rubbing...
1969k10stepside is offline   Reply With Quote
Old 07-23-2007, 02:01 PM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: 2wd lift kits??
it does have the leafs on the rear
Old 07-23-2007, 07:10 PM   #4
Ackattack
Ackattack's Avatar
Re: 2wd lift kits??
if it has leafs in the back then you can use the blocks, have new springs made, shorten the shackle,
or you could flip the shackle. If I remember right, on our trucks the leaf attaches above the shackle. If you unbolted the shackle and move it so the spring is under it, it would lift it too. 2 problems I see doing this. 1) It may not work without grinding, but I think if you swiched the shackles side to side, it would work. 2) Probably going to need some shims to correct the pinioin angle.
Good luck!
Ackattack is offline   Reply With Quote
Old 07-26-2007, 06:21 AM   #5
pooz911
pooz911's Avatar
Re: 2wd lift kits??
Lift the front end first and see if your truck sits level. My truck has only the overload springs in the rear. 33 inch tires, rancho front springs, ball joint spacers and a 3 inch body lift. clears 33 inch tires w/ 9.75 x 16.5 wheels.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 07-26-2007, 06:28 AM   #6
pooz911
pooz911's Avatar
Re: 2wd lift kits??
if you decide on installing the bb springs, let me know and I'll give you some pointers.
