07-25-2007, 10:04 PM | #1 |
cab swap help
Will any cab 67-72 that is a 2wd truck work on a 4x4 frame. I may need to get a bigger hump for the floor but isn't that the only differance.
My next question is Do all of the 4x4 v8 engines sit closer to the firewall than they do on the 2wds? |
07-25-2007, 10:18 PM | #2 |
Re: cab swap help
Yes all 67-72 cabs will bolt up, I hear that you dont even need the high-hump unless you are running a TH-400 tranny. I'm not sure about all 4x4's mounting the engine in the same location, I do know Its tight when You run an HEI..
I'm somewhat in the middle of putting a 2wd cab on a 4x4 chassis. Right now the tranny (TH-350)setting in place, but the cab is held up by 4x4 blocks. I will let you know if I have any clearance issues after I install the cab mounts.
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
07-25-2007, 11:03 PM | #3 |
Re: cab swap help
please keep me posted. thanks,,,and if you have any pics that would be great.
07-26-2007, 08:04 AM | #4 |
Re: cab swap help
You don`t need the high hump to use a TH400 in a 2wd application as long as your cab mounts are good.But,you do need the hump for a 4wd no matter if you have a TH350 or 4spd.Especially the 4spd since it is a tall transmission w/shifter on top.
All 4wd V8s are mounted back from the 2wd position and are close to the firewall.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-26-2007 at 08:06 AM. |
07-26-2007, 11:41 AM | #5 |
Re: cab swap help
hello,,on my 76 i screwed up bad,if u go from 2wd to 4wd not only do u need the higher hump but the piece underneath the seat needs changed too,there is pics in my post somewhere about it.it's raised under the seat to miss the rear of t-case.least on mine it did..
07-27-2007, 12:56 AM | #6 |
Re: cab swap help
I just saw one with an auto trans without the large hump. the guy said he swaped cabs. I don't think it would work with a 4 speed though.
It would be nice to have the access, can't you unbolt the high hump. Who sells them and are they expensive? |
07-27-2007, 08:54 AM | #7 |
Re: cab swap help
You have to get one from another truck.I thought they were all bolt-on.But,I`ve seen them stamped into the floor in one piece.I think it was some of the 2wds that didn`t come off.
07-27-2007, 10:24 AM | #8 |
Active Member
Re: cab swap help
Very easy conversion. Set high hump cover over molding on floor, mark mounting hole, remove cover and cut 1" inside holes. Use J-nuts to bolt on.Only takes about an hour. You can move engine to front holes if you put in at least a 4" lift. Reason for being in rear hole was clearance pan to diff. Will put more weight forward though, I haven't had any problems though.....good luck.....Rick ps I have covers for 67-72 and 73 up
07-28-2007, 11:26 PM | #9 |
Re: cab swap help
I used a 2wd a/c cab that had a low hump floor on my 71 K10.Remember,the low humps werent bolted in and the high humps whether the truck be a 4spd,big block,or 4wd had bolt in high humps.Same cab but they cut the floor out.You can see where the floor needs to be cut by comparing a low hump and high hump cab.Just follow the contour of the floor.The high hump will sit in place on a low hump floor and you know where it needs to be cut.The high humps had nuts welded to the floor on the bottom for where it bolts down.I just used metal screws to hold my floor hump down though.
As for the motor positioning,the 4wds were mounted farther back for differential clearance.You can move the motor/tranny/tcase forward but then factor in the driveshafts needing lengthened and shortened,The fan positioning,etc. Last edited by 1969k10stepside; 07-28-2007 at 11:28 PM. |
