Next project: 1970 K10
Glock's Camaro rear disc brackets are ready to ship!
ALL SOLD OUT!!! I will be gauging interest for another batch in the near future.
The Camaro rear disc brake conversion brackets are ready to ship! The kit includes the brackets, mounting hardware, metric brake line adapters, and full instructions including a parts list with part numbers and where to get them. This is a simple, inexpensive conversion to complete. See this thread for more details: http://67-72chevytrucks.com/vboard/s...d.php?t=249073 The kits are $92 shipped ($80 kit, $12 shipping). Paypal is prefered at glock35ipsc at aim.com. Thanks!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 08-16-2007 at 12:07 PM. |
Re: Glock's Camaro rear disc brackets are ready to ship!
Looks good !!1 Can't wait to get them and install them...Great Job!!
Cowboy Fan for Life!!!!!!
Sweet!! Those sure are some good looking calipers..
![]() http://www.car-part.com/ Glad to see it all coming together for you. ![]()
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
![]() Join Date: Nov 2002
Mr. Bob,
You had said at one point that you were going to include instructions for installation, as well as a needed parts list. Does that still hold true? I'm still trying to figure out if I need to buy the parking brake brackets (described in your other thread: http://67-72chevytrucks.com/vboard/s...=249073&page=2, my post #44). Thanks, Jeff aka TruckSTR
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
Yes, they will include instructions as well as a parts list, with the exception on the e-brake cable bracket. I have a used set of calipers that will probably be eventually used as a core for new ones, so I will keep the brackets off of this set. I would definitely think a dealer could hook you up, but I will see what I can dig up.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
You are da man!
Damn Yankee
Nice looking kit!
Why is everyone coming out with this stuff after I ordered a kit?..DOH! |
#8 | |
Just an FYI for those contemplating powder coating.
Powder coatings range from as little as 1 mil thickness all the way up to 6 or even 8 mils thick. Somebody would really have to be trying hard to lay the stuff on thick to get on the high end of that range. ![]() Regular spray paints range from 0.5 mils up. There really isn't an upper end, only an "acceptable" thickness (read: it don't crack and it looks good). Don't forget, however, that to apply paint, prep work has to be done, i.e., degrease, prime and paint (that's at the minimum - if you want it to last). Powder coating prep work essentially requires only that the surface be degreased, then powder coated. So, hopefully, those interested can see that neither painting or powder coating (if applied within reason) is going to add much thickness. Sprayed on powder coating does. However, tend to be just a little bit "wavier." Take a block and some fine grit sandpaper and a couple of strokes will smooth it right out. Also, FYI, 1 mil = 25.4 micron = 0.001" What am I going to do? I haven't quite decided yet. I want to make sure that there isn't any mechanical movement between the pieces that would tend to "wear" the coating (whatever it is) so that the result is a loose condition - not what you'd want in brake mounting parts. I might even just clean the various mating surfaces, make sure that everything is nice and clean and tight and then apply either POR-15 or an Eastwood paint to protect the pieces from rusting. If I need them apart, then I may have a fight on my hands. lol
The LuvShack Garage
ttt
New Member
![]() Join Date: Jul 2005
I would like to order a set of the Camaro rear brackets. Do you take Paypal?
Plugger7 |
Plugger7 - I do, check the last line of my first post in this thread for the address. I replaced the @ with at to ward off spam.
All of the kits that were pre-paid shipped out Friday and yesterday. Thank you!
I have 5 kit left as of today......
#15 |
GM ONLY BABY!!!
I guess that these brackets need to welded on the axle tubes, correct? What's the approximate total cost to purchase these brackets and get the calipers, and pads? Will the brake lines thread right in? Thanks!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#16 |
No welding, they bolt to the axle flange, where the OEM drum brake backing plates bolt to. Depending on where you get you parts (and new/used) it can be done for $300-$400. The kits include the metric brake line adapter to combine the Camaro brake hoses with the standard brake line fittings on the truck. The bracket set is $92 shipped.
#17 |
![]() Join Date: Sep 2002
Wont we have to change prop valve to all disc one.
Certifiably crazy person |
#18 |
www.mpbrakes.com (Master Power Brakes) has all kinds of info on what you need (and you don't have to use their parts either).
Here is the basic disc/disc setup: http://www.mpbrakes.com/uploads/docu...iscdiagram.pdf I also found this: http://www.mpbrakes.com/uploads/docu...rearadjust.pdf That makes me think that such an adjustment is required for the Camaro PBR calipers. Anyone know for sure?
#19 |
Glock35ipsc.. if you still have a set left put me down, I also sent a pm.
Harrol 1968 SWB 1968 SWB 4x4 1969 Suburban 1970 LWB 1970 Blazer 2002 Tahoe Inside every older person is a younger person wondering what happened |
#20 |
Harrol - I got you Paypal, thank you!
All of the Camaro brackets are sold at this time. I do still have several sets of the Impala caliper brackets left. I will be gauging interest on the Camaro units to possibly make another run of them sometime soon. Thanks everyone!!!!!
#21 |
![]() Join Date: Feb 2008
Do you have any made or plan on making more?
#22 |
![]() Join Date: Aug 2003
Bump.
#23 |
Loving the Jimmster
ttt
#24 |
![]() Join Date: Jan 2007
bump to get this rolling again...
If we have to prepay to get these going - I am in for one (at least). |
#25 |
![]() Join Date: Nov 2007
Count me in too!
