Old 07-27-2007, 12:09 PM   #1
bad_burb
bad_burb's Avatar
Dash lights don't work
None of my dash lights work in the '74 except the turn signals, bright indicator and the brake indicator. All of the bulbs have been changed.
Besides the obvious fuses what could be causing this? Possibly a ground issue? Where are they grounded to? What things should I be looking for? Any help would be appreciated.
'73 C-30 3+3 Dually 454/TH400
'74 Fleetside 350/TH350 (SOLD)
'69 Nova 350/TH350 (project FOR SALE)
'63 Nova 305/TH350 3.73 posi (the wife's project)
bad_burb is offline   Reply With Quote
Old 07-27-2007, 03:54 PM   #2
benoit454
Chris
benoit454's Avatar
Re: Dash lights don't work
I know it's a dumb question and I don't know if the lights you have that are working, work with the others in this way or not, but I KNOW it's happened to me several times.
Are they dimmed too much? I can't tell you how many times mines been dimmed down by accident and I think all the lights stopped working.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-27-2007, 07:11 PM   #3
bad_burb
bad_burb's Avatar
I did check to see if the light were dimmed too much but that was not the problem. I was thinking of replacing the headlight switch and see if that works.
Old 07-27-2007, 04:24 PM   #4
Jonboy
Slots go on anything!
Check the switch and the dimmer switch also.
Jonboy is offline   Reply With Quote
Old 07-27-2007, 04:55 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
Sometimes the printed circuit behind the cluster goes bad. Mine was all sorts of screwed up, if I turned my lights on the gas gauge and voltmeter stopped working, but they worked fine with the lights off. Half of the light bulb sockets were dead too.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-27-2007, 07:17 PM   #6
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
they ground to the side of the cab right behind the dash. as for anything else check the plug it might be off a bit. also check to if you have any dead ends in the circit board
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-28-2007, 04:15 AM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
twist the lights knob counter clockwise...if that doesnt work...then its further out than I can manage
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 07-28-2007, 11:18 PM   #8
f.monroe
f.monroe's Avatar
Check your tail lights , I think they are out when your dash lights go out . My 77 in highschool used to lose the dash lights and it was an indication that the tail lights were out . Mine was a pinched wire between the bed and frame . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-29-2007, 12:15 AM   #9
bad_burb
bad_burb's Avatar
The tail lights do work as do all other exterior lights. I got a different cluster to try. We'll see if it works.
Old 07-29-2007, 10:36 PM   #10
bad_burb
bad_burb's Avatar
Well the different cluster didn't do anything.
