Old 07-27-2007, 10:00 PM   #1
jimi121v
stroker ? for the engine guys
I have my 400 crank turned down to fit the 350 block, I have the correct damper for the 400 crank, and I just wanted to make sure the flywheel from the 350 will work. ???? It is a manual trans 72 4x4.
Thanks, Jimi
jimi121v is offline   Reply With Quote
Old 07-27-2007, 10:09 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: stroker ? for the engine guys
NO! The flywheel will not work as stock. In fact I dont think any 400 sb was out of the factory gate with a manual trans. There are adapters for this application though. The 400 must be balanced front and rear. Or have the whole crank assembley balanced, and use the 350 balancers.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-28-2007, 07:59 AM   #3
see ten
WTB this ad
see ten's Avatar
I don't know if it was stock but my little bros Blazer had a sb 400 and a granny 4sp when we got it. When we changed it to a 350 we had to change the flywheel due to the 400 being externally balanced (seems like it had weights on the flywheel). Didn't realize they were differnt til we had it running !
see ten is offline   Reply With Quote
Old 07-27-2007, 10:32 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
You can order a crank that is internally balanced for a stroker motor, but a stock 400 crank is externally balanced and a 350 flywheel or flexplate will NOT work on the 400 crank.
Old 07-27-2007, 10:37 PM   #5
manimal
manimal's Avatar
You should have the entire rotating assembly balanced anyway. Are you going to use 5.7 rods or 5.56 (stock 400) rods? Forged or hyperutectic pistons? There are a lot of thing s to concider when it comes to balancing an engine. For the street an external balanced engine is just fine,dont waste your money on having a stock crank internally balanced. JMO
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-27-2007, 11:27 PM   #6
piecesparts
After my last experience of a rod through the side of the block on my stroker motor, I recommend that you get a quality brand of rods and a good crank when you build the motor. I put mine together with the 5.7 rods, both times; but this last build went together with H-beam rods and a forged crank. The other crank received damage when the rod started doing it's own thing in the block. We chose stock rods the first build and the rod gave away just above the mounting journal to the crank. As I stated above, you can get an internally balanced 400 crank and the one that I ordered this last time was just that. It was not much different in price than a forged externally balanced one. The previous crank was externally balanced and worked just fine on my street truck, but it is now in the salvage yard.
Old 07-28-2007, 07:51 AM   #7
mnunn454
mnunn454's Avatar
One of the problems of assembling all the parts/pieces at home is the individual takes on more of the risk of [failure from] the pieces not playing well together. Building from scratch is great for the technically knowledgable or the person with a fat budget to work with. But if one or both of those are lacking, it may not pay in the long run to take that risk. These days you can get a balanced stroker rotating assembly for not a whole lot more than it'll cost to assemble all the finished pieces yourself. I'm personally well able to build a stroker from scratch. But were I wanting a 383 today, I'd either buy an entire rotating assembly from a reputable company, or a complete shortblock with a warranty.
JMO.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 07-28-2007, 08:30 AM   #8
piecesparts
JMO.
No problem with what is stated here. The only addition to that would be to have a good understanding before purchase, just constitutes warranty support. This means know what they will do and what they will not do. Also remember everything will be by mail and freight--the local machine shops are just down the street. We built my motors locally, because my Machine Shop buddy and I get along real well. What I don't know he is there to assist.
Old 07-28-2007, 08:31 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they did have stock 400 small blocks with manual trannys bolted up... but they are far and few between though.
Old 07-28-2007, 09:20 AM   #10
cooters
as far as i know 454 flywheels have the same balance as 400s, and they definetly bolt on.
cooters is offline   Reply With Quote
Old 07-28-2007, 09:23 AM   #11
crazy longhorn
Fabricate till you "puke"
NO THEY DONT!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-29-2007, 01:09 AM   #12
kwmech
They will bolt on, but the 454 has more counter weight, it will have to be balanced for the 400. I've done it myself for the 12'' disc surface.
Old 07-29-2007, 01:35 AM   #13
crazy longhorn
I dont follow? The same sb flywheel that handles an 11 " disc , will also handle a 12" disc. I have installed 12" discs on a 350 sb....the hat for the 12" has the same bolt pattern as the 11"....... L
Old 07-30-2007, 12:47 PM   #14
Billla
Billla's Avatar
The flange is the same and it's also externally balanced - but the size and placement of the weights are drastically different. "Definitely bolt on" to me indicates it can be used out of the box...and it clearly can't.
As noted, a balanced assembly is worth the money. Note that a matched balancer is required.
Am I missing something in this debate about how easy they are to find? Summit has 9 of these in their catalog...
http://store.summitracing.com/egnsea...115+4294871900
Billla is offline   Reply With Quote
Old 07-28-2007, 09:21 AM   #15
crazy longhorn
Best bet is aftermarket on the 400 sb flywheel......try Northern autoparts for a stock replacement(cast flywheel), or Hays ,or Centerforce (billet) can be had for a few more bucks. IIRC, my Hays was around $225, & Centerforce was a tad more. The stock replacements were around $120. I would rather go this route, than bolt a balance weight on the rear.....but DO be sure to have all the pcs balanced with the crank Best of luck, L
Old 07-29-2007, 01:23 PM   #16
eedgell
eedgell's Avatar
Best to have a balanced assembly. Solves most of the trouble.
Eric
Old 07-29-2007, 07:55 PM   #17
cooters
i think you missed the point crazy longhorn, the 454 flywheel WILL bolt onto the 400 crank, but is the balance the same or not is the question now.
Old 07-29-2007, 08:38 PM   #18
crazy longhorn
No sir, I didnt miss the point! I know that the 454 flywheel will bolt onto the 400 crank, & no the balance is NOT right for a 400 sb. What I question is why use a 454 flywheel to run a 12" clutch, when the 12" clutch fits on the small block 400 flywheel(168 tooth flywheel)? I am sure that you can balance the 454 flywheel with the 400 crank & make it work, but now you have "bastardized" the setup. In the event that you ever have to swap that flywheel, you just may have to rebalance the crank to "fix" it L
Old 07-29-2007, 10:30 PM   #19
cooters
the concept of the 454 flywheel came up because it may be easier to find a 454 flywheel than a sb 400 but since the balance is different it is not a good consideration.
Old 07-30-2007, 12:16 PM   #20
jimi121v
Thanks for all the input. I guess I'll have a couple "tree-fitty" flywheels for sale on E-Bay soon.
