Old 08-02-2007, 02:25 PM   #1
crazy longhorn
Fabricate till you "puke"
Spray in bedliner
DIY, or hire it done? In my area , I have Rhino liner, or Line -X available. I have also looked at several DIY spray or roll in liners.......whats the best route? Help!!! L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-02-2007, 02:31 PM   #2
cdowns
cdowns's Avatar
Re: Spray in bedliner
you cant get the results at home// on my 04 silverado i did linex and it has held up excellent to heavy abuse and constant florida sunlight i will use again in the future// i've seen many home jobs thin peeling and faded after a couple of years of use
Old 08-02-2007, 02:33 PM   #3
Joe67
67 is sold
You will hear debate about Line-X or Rhino all day long. they are the two big hitters. I would go with either of them.
I have a Rhino in my GMC and love it.
One thing with these, when you see the commercials where they dump a pile of bricks into the bed, you will have a dented bed, and the bedliner will tear
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-02-2007, 02:41 PM   #4
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
I got a Scorpion liner in mine... Same thing as a rhino really. On one of my fathers trucks we did a home job and the previous posts are right. It's impossible to get it as thick and even as the spray ins.
Pl4yboy is offline   Reply With Quote
Old 08-02-2007, 02:58 PM   #5
RedZ71
Junior Member
RedZ71's Avatar
i have DIY in my 2001 silverado. JUNK!!! i saved $350 in the beginning... but now im regretting it 100%. sanding it all out is not going to be fun, but ill be damned if im going to pay $400 to have the bed prepped before i have a new one sprayed in properly.
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 08-02-2007, 03:31 PM   #6
ChevyDude
GatorHyde has a speacial ISO-Prime II that is applied first to an old liner and then we spray right over your old liner. Of course all loose stuff has to be removed.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 08-02-2007, 03:49 PM   #7
FREEMAN70
FREEMAN70's Avatar
Thumbs up Re: Spray in bedliner
i work at JENKINS AUTOBODY and we spray speedliner, hole lot better than rhino bed liner, where rhino dries in a few minutes, speedliner is a full chemical cure , at 72 degrees it takes 72 hours for a full cure thats why it does not fade like any of the other. We have done a bunch of them for the railroad company and consturction companies. its realy good stuff.
IF YOU LOOK AT MOPAR MUSCLE YOU HAVE SEEN OUR WOORK WE MADE THE FRONT COVER WITH A DODGE DART SWINGER.
FREEMAN70 is offline   Reply With Quote
Old 08-02-2007, 04:24 PM   #8
GMC AMI
GMC AMI's Avatar
Wink Re: Spray in bedliner
A chemical stripper will soften the bedliner so removal will be easier!
GMC AMI is offline   Reply With Quote
Old 08-02-2007, 04:42 PM   #9
Scott68-93-97
Scott68-93-97's Avatar
Brake fluid works great to get rid of an old liner
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 08-02-2007, 09:30 PM   #10
RedZ71
Junior Member
RedZ71's Avatar
yeah im debating if im going to scrape it, or if im gonna try to sand it.
Jonathan
1971 LB C10 Custom
Old 08-02-2007, 03:27 PM   #11
ChevyDude
I spray GatorHyde everyday, except Sunday. GatorHyde was voted "Best Spray-In bed liner in todays market by TRUCKS TV show. Over the years I have had every bed liner that is out there even a DIY. I would reccomend you get a HOT, HIGH PRESSURE , Hybrid PolyUreathane/PolyUrea liner installed. The cold low pressure has it's following but IMO, go HOT HIGH PRESSURE!
Alex
Alex
Old 08-02-2007, 03:46 PM   #12
Scott68-93-97
GatorHyde is the same as line x hot, high pressure d use one of those two, Rhino and other cold low pressures don't hold up to the abuse, plus if you take a sample of line x and a sample of rhino and rub them together the line x will sand down the rhino, plus with the high pressure the texture is cleaner and more consistant, the heat allows the material to dry faster at line x you can usually have your truck back in a couple hours, instead of having down at rhino all day
Old 08-16-2007, 11:57 PM   #13
Solego
Dr. Frankentruck's Monster
Solego's Avatar
Holy Cow!!! Use some punctuation, I almost passed out!
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 08-17-2007, 11:46 AM   #14
Scott68-93-97
There's a few ,,,,, in there, I'm at work on break a lot of the time I have to spend on the CPU so I'm typing as fast as possible. But thanks for the grammer lesson......
Old 08-02-2007, 04:48 PM   #15
70c10
67-72 Addict!
70c10's Avatar
Alex
I agree 100% on high pressure!. I love mine in my ZR2
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-02-2007, 07:00 PM   #16
avysittinon22s
avysittinon22s's Avatar
Get a liner that is 100% polyurthane. Rhino is 100%. I spray ArmorThane which is also 100% poly. Tryed Scorpion a few years ago and would tear very easy. Line X has a good liner but is alot harder than the Rhino. Speedliner is like Line X, they are both hard like a plastic liner. Rhino and other poly liners are not as hard so bed may dent easier, but cargo wont slide around as bad. Most of the time with any brand of liner fading is due to improper mixing. I would never have a roll on or spray bomb type liner. They are cheap and all I have seen look like garbage. The drawback to poly is the colors. You can have colors, but poly liners wants to turn back to its orginal color which is a yellowish white. With black die fading is very very minimal due to black being dominant. I have sprayed some tans, grays, and couple of burgindys and have not had any come back with a compliant. Also how good it is sanded depends on how well is gonna stick to the truck, just like paint. So if it was mine I would get a Rhino, ArmorThane or some other 100% poly liner.
avysittinon22s is offline   Reply With Quote
Old 08-02-2007, 07:22 PM   #17
Scott68-93-97
Line x is not plastic it is polyurathane also mixed with a iso.. which is a super glue mixed with the poly in the gun at over 5000 psi at a tempature of around 200 degrees.
Old 08-02-2007, 09:19 PM   #18
avysittinon22s
Hard LIKE a plastic liner. I didnt state that is was plastic, because it is not. It has polyurethane mixed in but is not 100% poly.
Old 08-02-2007, 04:05 PM   #19
gkolmatycki
Love that '69
I got my bed liner sprayed in by professionals in town. Looks good & lasts longer than doing it yourself. Kind of a messy job to do yourself too.
I AM CANADIAN & PROUD OF IT!!!
1969 Chevy C10, SBC V8, TH-350 Transmission, Metallic Blue, B&M Megashifter, GT Grant Steering Wheel, 2.25" True Dual Magnaflow Exhaust System w/ SS Magnaflow Embossed Tips, 700W Rockford Fosgate Stereo System, Lowered 1" Front & Stock Rear, 4.56 Rear with Positraction, 15" Chrome Rims w/ Chevy Center Caps & Michelin Tires, 4.5" K&N Air Filter, Edelbrock 'Elite' Engine Accessories, Chrome Powdercoated Engine Parts
2001 Cavalier Z24, 2.4L DOHC, Silver, Spoiler, AEM Intake, 2.25" Magnaflow Exhaust System, Clear Euro Tails, Tinted Windows, 400W Clarion Stereo System
gkolmatycki is offline   Reply With Quote
Old 08-02-2007, 09:40 PM   #20
'68 longbed
'68 longbed's Avatar
seems like a wire wheel would work pretty well
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 08-03-2007, 12:18 AM   #21
72armyswbtruck
72armyswbtruck's Avatar
I knew that Gator Hyde would chime in, shame I don't live a little closer to Denver i would have him do mine.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-03-2007, 06:20 AM   #22
crazy longhorn
Many thanks for all the replies! I sure dont need a DIY headache that needs to be scraped out 6 mo down the road I like the idea of hot /high pressure liner, it looks to be a smoother install( at home in a hotrod, as well as a lite hauler). L
Old 08-03-2007, 10:27 AM   #23
ChevyDude
That's because the machine that delivers the material (Graco EXP-1 Reactor) is a 12,000 dollar piece of equipment, the heated (50 ft) hose and Fusion gun are another $4,000. A DIY can and roller just are not in the same ballpark. And as they always say...Ya get what ya pay for!!!
Alex
Old 08-03-2007, 07:15 PM   #24
see ten
WTB this ad
see ten's Avatar
Rhino here. Its got pros and cons, but I'm sure they all do.
see ten is offline   Reply With Quote
Old 08-04-2007, 09:00 AM   #25
ChevyDude
I'll chime in...but as I have said before....I really don't care what brand of liner someone wants to get. I spray 20-25 trucks a month, every month. and Have never had any one say anything other than "Man that looks good". As far as RNO goes...it is a cold applied, low pressure, and does the LONG TIME dry , I think they say 4 to 6 hours. It is straight PolyUrethane...and because of that it is prone to Chalking out or fading much quicker than a Hybrid formula....Anyway hope you get what you want. I gotta get to the shop. A guy is driving into Denver from Kremmling, CO (2.5 hours away) to get his truck sprayed with GatorHyde!!! The longbed truck from Kremmling I am spraying for a $450.00 deal.
72armyswbtruck......road trip!!!! Come on down!!! You come down and I will let you spray your truck yourself at cost!!!! No kidding!
Below is an "under rail" spray. I perfer over rail, but I do what the customer wants!
Alex
Alex
