Old 09-25-2002, 12:30 AM   #1
mikep
Used to have a truck
mikep's Avatar
Heater Hi not working
I put my heater on hi but no worky. Just makes a growling sound. Its got a new heater relay. Doesnt seem like a switch problem. Is there a resistor or something I am missing here. It only does this in the hi range. This is an air conditioned truck if that makes any difference
No truck :-(
mikep is offline   Reply With Quote
Old 09-25-2002, 12:50 AM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
sounds more like the fan motor to me. run a wire from the battery to the fans power terminal (in the engine compartment) see if the fan runs on high that way. if it doesnt, bad fan, if it does, prob one of the other things.
there are 3 major causes for this. first is the switch. 2nd is that relay (right of the glove box under dash) and the third... um, name is escaping me right now, but its INSIDE the duct work just below and to the left of the glove box. only thing left is the fan motor.
good luck, i chased mine for a month before i found out it was mis wired at the switch!
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-25-2002, 01:19 AM   #3
barn9
Half a bubble off!
barn9's Avatar
I once had a bad wire going to the high speed relay under the glove box. The wire was half melted from getting too hot. When I re-built the harness, it got a little heavier wire.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 09-25-2002, 07:27 AM   #4
mrein3
mrein3's Avatar
A lot of GM cars and trucks have an in-line fuse for the high-speed position on the fan. Look for an orange wire along the top of the firewall.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-25-2002, 07:47 AM   #5
Huck
Huck's Avatar
Had same problem with two different a/c trucks. In both cases it turned out to be bad grounds---one at the relay and one at the motor it's self. High speed fan failure seems to be a common problem with the wiring design on these trucks~~~.
Huck is offline   Reply With Quote
Old 09-25-2002, 09:50 AM   #6
Hutch
Hutch's Avatar
Try the Ground wire from the high speed relay behind the glove box. There is a short wire from relay base to the firewall mountingbolt that is nearby.
It could also be the ground inside the engine comparment from firewall to the fan base.
Symption are low speed is very slow, Medium speed works and High returns to a very slow speed
You can use a small section of wire for a test.
The plastic plug to the fan switch under the dash carries alot of current and is usually melted, make sure it is making a good connection.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
