08-09-2007, 01:20 PM | #1 |
Active Member
Driveshaft Slip Joint Seal
The seal for the slip joint on my two piece driveshaft is shot. Where do you get a new seal? I dont think I can replace the seal because I can't get the collar loose. How do you keep the grease in the yoke without a seal?
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
08-09-2007, 07:58 PM | #2 |
Re: Driveshaft Slip Joint Seal
I have had good luck getting the collars off by spraying them with penetrant, tapping around the collar with a hammer and then use a channel lock pliers to remove them. I have yet had to use heat, but that is an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-12-2007, 03:50 PM | #3 |
Active Member
Jim
Thanks for the tip. After soaking it for a couple of days and a few gentle taps with the hammar it came right apart. What a great board. Don
04-11-2017, 02:43 AM | #4 |
Okay, so you got it off...where did you find a new seal?
04-11-2017, 07:53 AM | #5 |
Active Member
Try LMC truck or Ecklers.
04-11-2017, 08:45 AM | #6 |
the boat guy
Any driveline shop will have them. How are the slip and stub? If they have lateral play they shouldbe replaced.
04-13-2017, 03:09 AM | #7 |
LMC, nope. Ecklers, nope. Driveline shops, pretty thin on the ground these days. Just re-used the old seal. It's a driver, not a showpiece.
04-13-2017, 03:28 AM | #8 |
How about you just go to your local Oreilly's and pick one up for 10.00
http://www.oreillyauto.com/site/c/de...1418&ppt=C0362
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
