Spanked once
![]() Join Date: Oct 2006
Pixie and Dixie Evicted
Before I noticed the outside of my plenum was smashed in I had already cleaned at this area from the cowl with a vacuum cleaner.
I hate mieces to pieces ![]() Previous damage.. http://67-72chevytrucks.com/vboard/s...d.php?t=248377 Last edited by Richard H.; 08-09-2007 at 04:35 PM. Reason: z |
The LuvShack Garage
Re: Pixie and Dixie Evicted
Man that sucks
Hmmm.....Might not be a bad idea for me to take mine apart and check. I'd hate to cut a hole for no reason but then again I'd hate to not and have a bunch of crud in there.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
Spanked once
In the bottom near the kick panel there is a weep hole big enough for a giants tears if you can get to it or you may have to remove the heater and use a heater hose or something on a vacumm cleaner.
What is that, about an R-30 insulation value??
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 08-09-2007 at 03:52 PM. |
Wonder if that guy ever got his pet badger??? He'd be right at home in there.... and if ever needed, he'd probably kick the truck monkeys a$$.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
Designated A-hole!
Or use an air hose and be patient.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Take out the kick panel vent. You can reach inside with a vacuum nozzle (small one) and clean it out. I also used an air hose to move the stuff around so I could get to it all. You can see the back of the vent in the picture.
Open the vent, on the top is a rod that the bottom of the rod is held by a spring clip. Push up on the clip and down on the rod and out comes the vent. |
Here is a suggestion for you guys that do cut the outside of the vent open to clean it out, like richard did. Any truck I do this to I make a patch panel that I put seam sealer on and rivit on so that if it has to be pulled off again it cna be somewhat easily done. Plus I bedliner the inside area like crazy when I do that.
