Old 08-12-2007, 03:22 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
4x4 Chassis ID + Value
I am looking at truck to part out.
The body is a 1950 Ford however it looks to be on a GM chassis.
It has PS (saginaw box), PB, ( hydroboost), 4 wheel drive with at least a dana front axle, posi rear axle.
Come someone tell me where to look to ID the chassis, transfer case.
I would guess it is a mid 80's but really have no clue.
It drive, 4wd works, brakes work, if the chassis, transfer case and T400 is worth anything let me know.
Was Hydroboost a factory installed item?
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 08-12-2007, 07:09 PM   #2
1969k10stepside
Re: 4x4 Chassis ID + Value
Post some pics and I can give you a time frame of the year if its a 67-72.If its got a turbo 400 it likely isnt a 67-72 frame as there wasnt turbo 400s in the 4wds but it could of always been added.There is a vin on the front of the frame but with pics its easily identified.Also post a pic of the t-case and it can be i.d.'d too
1969k10stepside is offline   Reply With Quote
Old 08-12-2007, 08:06 PM   #3
BurnoutNova
BurnoutNova's Avatar
they didnt put them in any 4x4 67-72's ??
BurnoutNova is offline   Reply With Quote
Old 08-12-2007, 10:59 PM   #4
1969k10stepside
Nope,only turbo 350s
Old 08-13-2007, 07:51 AM   #5
Blazer1970
Blazer1970's Avatar
If it really has a turbo 400 and hydroboost, it would most likely be a '77 or up K30. That also means it would have a Dana 60 front axle. Post some pics.
Blazer1970 is offline   Reply With Quote
Old 08-14-2007, 09:17 PM   #6
1968SWBBigBlock
Active Member
OK here are some pics = the tranny is a turbo 350
Again it does have Hydro boost with front disc brakes PS with a saginaw steering box and a GM tilt steering wheel
1968 SWB
Old 08-14-2007, 09:33 PM   #7
1969k10stepside
On the rear shocks,do they both point towards the cab or the passenger side pointing forward and the drivers side pointing to the rear bumper?I see a swaybar,which the 67-72 4wds didnt have.It could have been added but the chassis is possibly a 73-??.The axles are 1/2 ton.12 bolt rear,44 front.
Old 08-14-2007, 09:42 PM   #8
1968SWBBigBlock
Active Member
staggered shocks- drivers side points back, passenger forward
1968 SWB
Old 08-15-2007, 12:00 AM   #9
1969k10stepside
Then that would be a 73-78 or so 4wd,assuming the front differential is original.Around 78 or so they went to the Corp. 10 bolt front.
Old 08-15-2007, 01:53 AM   #10
BurnoutNova
can a 73+ sway bar be installed on a 67-72 k series truck? the top spring plate looks like it might work
Old 08-15-2007, 07:52 AM   #11
Blazer1970
Blazer1970's Avatar
It can be done pretty easily. You have to do some fabbing for the upper mounts.
Old 08-15-2007, 08:58 AM   #12
1968SWBBigBlock
Active Member
Ok any idea on what the transfer case is?
What about value for the entire set up rolling with tranny, transfer case, front and rear axles.
1968 SWB
Old 08-15-2007, 09:43 AM   #13
OLDCHEV4X4
OLDCHEV4X4's Avatar
Thats a NP205 case.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-15-2007, 04:07 PM   #14
earl87gta
earl87gta's Avatar
I would say its worth around 600 figure 300 to 400 for the trans and transfer case and then 150 to 200 for axles if you were to part it out you may be able to get 700 for it but it would take some time.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 08-16-2007, 12:28 PM   #15
hgs_notes
GEARHEAD
hgs_notes's Avatar
73 and up 1/2 tons did not come with a NP205 T case. Are the axles 8 lug or 6? If they are 6 lug, I think there may have been some swaps made. You could get a NP205 and Dana 44 front on 3/4 ton trucks though.
hgs_notes is offline   Reply With Quote
Old 08-16-2007, 12:38 PM   #16
us111
not positive but that t-case looks just like my 203
us111 is offline   Reply With Quote
Old 08-16-2007, 04:03 PM   #17
earl87gta
earl87gta's Avatar
That case is a 205 for sure and its posible that it is out of 1/2 ton just not 73 more like 83 and since its a 400 trans I would say half ton 6.2 diesel truck or burb both came with a 400 trans up to around 84 85 then they went to the 400 with 208 or 241 in the 3/4 and one ton and the 1/2 ton got a 700r4 with a 203. I get them dert cheap around 600 for the hole burb or truck if it doesnt run. Get the BOM number off the front axle and we can look it up.
Earl
Old 08-16-2007, 08:57 PM   #18
1969 GMC
1969 GMC's Avatar
He said it was a TH350. This combo was factory in the 69-72 time frame, and then also in 1980, when all K trucks got 205's. My guess is that this truck is like a potluck dinner...not just a donor chassis.
K10's never got TH400/205 combos, neither did K20's for that matter...K30 only combo. However, some C10's got the TH400, and quite a few K20s got TH400/208 or 241 combos.
Also, the 700r4 never came with a 203 behind it from the factory.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-17-2007, 12:44 AM   #19
earl87gta
earl87gta's Avatar
I missed were it went from a 400 to a 350. I had a 82 6.2 diesel k10 and I dont rember it having a 700r4 in it I dont think it had over drive maybe it did its been years ago I know my 86 k20 has 400 and 241 in it. but if his has a 350 no telling what it came out of you can still get the BOM off the axles and look them up and see what they came from.
Earl
Old 08-26-2007, 09:27 PM   #20
1968SWBBigBlock
Active Member
OK I did find that tag and confirmed that this is an NP205 Dated in late 1972
So it should be out of a 73 truck
The rearend is dated 272 making it an early 72 rearend so it has most likley been swapped in, I am going to pull the covers and confirms insides and gears
1968 SWB
Old 08-26-2007, 10:06 PM   #21
BurnoutNova
ive seen a 73 blazer with a th350/ 205 combo but it must have been an early one
