Old 08-12-2007, 05:29 PM   #1
tys toy
tys toy's Avatar
How can I remove the ignition switch....???
Does anyone know how to remove the complete ignition from the dash. The front bezel seems to turn, but wont come off........
tys toy is offline   Reply With Quote
Old 08-12-2007, 05:36 PM   #2
combustion
Re: How can I remove the ignition switch....???
its really fine threaded. so if it seems like its turning and not moving, it is moving but very slowly. keep turning it until it comes off. if not the its already in fact ready to come off so just pull it off.
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 08-12-2007, 06:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll need to place a paper clip into the hole by the key hole, turn the key to the ACC position, then press the clip in as you try to turn the key further left... some pulling may be involved also.
Once that comes out, you can continue to unscrew it like you've been doing.
Old 08-12-2007, 08:15 PM   #4
cst70rocket
What if you don't have the key?
cst70rocket is offline   Reply With Quote
Old 08-12-2007, 08:19 PM   #5
msgross
msgross's Avatar
then get a BFH and chisel (aka Master Key).... just don't bend the dash!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-12-2007, 08:35 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
No key..............unplug the harness from the back of the switch, take a saw zaw and from behind the dash cut the switch in half, remove the parts and buy another switch assembly from a board member or ebay.
get the door locks to match since your are doing it.
Problem solved
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-12-2007, 08:36 PM   #7
lks dcvn
lks dcvn's Avatar
Ahhh - been there done that...
If you don't have the key - you can pry the small metal face off of the ignition key cylinder (the part where the key would go) - and then just replace the switch and the key cylinder.
Or - there are instructions on this forum from 'LockDoc' to remove the switch and key cylinder from the car without damaging either part, but it is a difficult procedure which also takes some lockpicking to do it correctly.
I searched for the link to the forum message that had the link in it...
http://members.zumatel.net/dgpurdum4...formation.html
Good luck...
lks dcvn is offline   Reply With Quote
Old 08-12-2007, 10:01 PM   #8
bozracer
wnc tvman
bozracer's Avatar
I took the door lock out ,took to a key shop and had one made then used it to remove ignition cylinder.
Oz WNC
67 Short Fleet 350 4speed
70 Short Fleet 327 4speed
bozracer is offline   Reply With Quote
Old 08-13-2007, 01:40 PM   #9
72freak
72freak's Avatar
This is the best suggestion Ive heard yet..........Locksmith should not charge more that $25. Cheaper than my earlier suggestion!!!!
Old 08-13-2007, 03:29 PM   #10
bad6772
Official Site Guitar Shredder
bad6772's Avatar
i thaught i was the only one that called it a BFH
bad6772 is offline   Reply With Quote
Old 08-12-2007, 10:13 PM   #11
1970bowtie
1970bowtie's Avatar
i took a drill and drilled the locking cylinder out. worked good and didnt damage the dash
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 08-13-2007, 12:00 PM   #12
rodstored-72
chevy truck fan
rodstored-72's Avatar
i am interested in doing this as well so i can paint the dash, if i may, a follow up on the no key issue? if you take the cylinder out is there any kind of a resale value for the cylinder & bezel if they are in working order???
thanks! rodstored-72
rodstored-72 is offline   Reply With Quote
