08-13-2007, 08:06 PM | #1 |
Stepside fenders on a fleetside bed?
I have a 1972 C30 "Dually" with a fleetside bed on it. I need to extend the fenders about 5" on either side to cover the rear wheels. I have a set of fiberglass stepside fenders that I want to cut to fit. I have seen this done before on these trucks. My question is to anyone who has done this is how do I cut them to match the profile of the fleetside bed. This is even more complicated as the profile of the bedsides change from one end to the other. Is there an easy way to do this.
Allen
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
08-13-2007, 09:26 PM | #2 |
sufficiently talented fool
Re: Stepside fenders on a fleetside bed?
68gmcdually has one that looks sweet!! I will PM him a link to this thread
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
08-13-2007, 10:07 PM | #3 | |
Rottenwood Garage Member
I am getting ready to do the same thing...I have a 133" wheelbase so I am using a longhorn bed. What bed did you use? How did it fit?
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
08-13-2007, 10:34 PM | #4 |
Use Cardboard To Make A Template Or Go To Eastwood, They Got Those Plastic Template Makers For Doing Body Work.
I BELIEVE IN JOHN 3:16 |
08-14-2007, 01:51 PM | #5 |
I have a radical idea!
I am currently in the process of doing this. You can use a protractor to mark the profile of the fleetside bed onto the stepside fender. Here is a step by step description w/ pics of how to do it. Its actually very simple to do. http://67-72chevytrucks.com/vboard/s...126946&page=13
Here's a bunch of inspiration pics for ya!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 08-14-2007 at 02:58 PM. |
08-14-2007, 01:54 PM | #6 |
A few more
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-14-2007, 02:00 PM | #7 |
I had to cut the frame on mine 6" to make it fit. I used a '97 C3500 pickup rearend. I was able to use factory bed mounts off the 1/2 ton truck on the 1 ton frame. It was a lot easier than I expected it to be. I had to drill a few holes and bolted the mounts in the front, and just had to drill holes for the 4 rear bed bolts.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 08-14-2007 at 02:56 PM. |
08-14-2007, 02:51 PM | #8 |
Never done this project myself, but I have a good bit of experience with scribing logs for log homes, I would think that the same scribes would work just as well for this (get one with the bubble on it so you know your scribe is true).
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
08-14-2007, 06:30 PM | #9 |
We scribed mine and it worked out really well. The only thing extra that we did that I recommend you do as well is to add onto the heels of the front and the back of the fenders so that they go down to the bottom of the fleetside box, if not they sit up about 3/4". Good luck.
08-14-2007, 07:55 PM | #10 |
Here's the project,
1972 fleetside shortbed 1969 C30 frame and running gear 74 454 W/TCI 400 transmission. The frame has been shortened to fit the shortbed. The bed floor will be wood. I fabricated a frame to mount the wood bed to the C30 frame. I was hoping there was some magical solution to getting the stepside fender mount on the bed.
08-14-2007, 08:01 PM | #11 |
Insert Title Here
wow, that slammed baby blue one is awesome
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
08-26-2007, 06:31 PM | #12 |
Wow, those look nice when done that way. Good work guys!
11-13-2008, 07:36 PM | #13 |
its all about the +6 inches
bump for reference toa PM i got
11-13-2008, 10:06 PM | #14 |
Here's some better pics of mine since I posted the others on this thread last year. Still not painted though!
