Old 08-17-2007, 08:52 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Frame questions ???
Ok guys
I plan to cut my truck down to SWB & lay the rockers about an inch or two off the ground at dump
My question is: am I better to Z the frame front & back, or build a complete new frame
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-18-2007, 12:35 AM   #2
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: Frame questions ???
I did a 3" Z and murdered my rockers.
I have a 12" notch out back for the 22"s with some room.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-18-2007, 01:02 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
Originally Posted by Spray-Bomb View Post
Ok guys
you can get that low without a z
my rockers are about 2" off the ground at full dump
bagged74 is offline   Reply With Quote
Old 08-18-2007, 12:21 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I guess I should have gone into more detail
I want to ride low, like rockers about 5" off the ground & I want my A-arms as level as possible at ride height
In the rear, I'm not gonna do a big step notch as I'm just gonna raise the frame up (most likely by building a new one) because Ima raise the floor too
I just figured that if Ima be cut'n the frame off front & back and try'n to keep everything aligned, It might not be much harder to build a whole new frame
Sinister
Killer
Old 08-18-2007, 07:32 PM   #5
bagged74
its just $$$$$
bagged74's Avatar
might actually be easier
Old 08-18-2007, 09:42 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Building a new frame ???
That is what I thought, plus it would make my truck that much nicer
Sinister
Killer
Old 08-18-2007, 10:44 PM   #7
Shane
Shane's Avatar
... it's also mega expensive
Shane is offline   Reply With Quote
Old 08-18-2007, 11:19 PM   #8
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Why ???
Sinister
Killer
Old 08-19-2007, 02:10 AM   #9
Shane
Shane's Avatar
Why ???
Cause steel prices are out of sight ... ESPECIALLY steel tubing - square and round.
Old 08-19-2007, 12:48 AM   #10
FnLow69
FnLow69's Avatar
why not "Z" the front and backhalf the rear?
early stages of design...
with tanks and compressors on.....
FnLow69 is offline   Reply With Quote
Old 08-19-2007, 06:55 PM   #11
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thats what I plan to do if I don't build a new frame, I just figured if Ima go to that much trouble I might as well build a new frame & it look sweet
Sinister
Killer
Old 08-19-2007, 08:47 PM   #12
bagged81
Signals in the bumper.
bagged81's Avatar
I just Z'd my frame 4.5" in the front and redid my notch in the rear and that was a lot of work, haha. I could not imagine building one from scratch.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 08-19-2007, 11:01 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I agree it won't be easy to the frame
Ok, so what do ya'll think is the best way to go
#1 mod my stock frame (back half & Z)
#2 build a new frame
#3 body drop it
#4 ???
Sinister
Killer
Old 08-19-2007, 11:25 PM   #14
Shane
Shane's Avatar
You Z'd it 4 1/2" inches? Holy smokes ... never heard of that big of a Z.
Old 08-20-2007, 09:46 AM   #15
bagged81
bagged81's Avatar
I did what it needed to set the rockers on the ground.
Jeff C.
Old 08-20-2007, 10:21 AM   #16
Shane
Shane's Avatar
my bad ... i was thinking of the sectioned crossmember ... duh
Old 08-20-2007, 11:39 AM   #17
bagged81
bagged81's Avatar
Yea, I could see where you'd be a little astonished about a 4.5" crossmember drop, haha.
Jeff C.
Old 08-20-2007, 12:22 PM   #18
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Z and back half. Building a whole frame isn't an easy task. Especially when it comes to the front suspension mounting. I have a 1.25" crossmember section, 3" Z and notch in the back with factory body mounts and I can't fit my fingers between the rocker lip and the shop floor. My ride height should be rockers 3-5" off the ground
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 08-20-2007, 01:03 PM   #19
7deuce
Sold! 2 days after finished
7deuce's Avatar
Id buy an IFS and build it. I did the 2 3/4 Z and a 1 1/8 cross member section back halfed it and ran 2x4 along the frame rails and cut the bottoms off to lay door and at the end I had the result I wanted but a modified stock frame. If you got the skill and the money to go that route thats what I would do. I looks good and really aint that hard to do as long as you have the stock frame next to the one your building. Ive built 2 custom frame since I did the 72 and it reall aint all that bad.
7deuce is offline   Reply With Quote
Old 08-20-2007, 01:34 PM   #20
abadsvt
abadsvt's Avatar
Here is my opinion based on my own experience building a whole frame. There is alot more too it than just slapping it together. I am going to play the devils advocate first. Okay! First off you have to have all the correct tools and setups. For example: You need a chop saw, mig welder at least (preferably a 220v mig), a large perfectly level and flat table helps out ALOT and highly recommended, lots of clamps, grinder, and a few other little tools. Then there is alot of careful measurements to make both sides EXACTLY the same, plus if you change anything you have to think ahead and see if it is going to alter anything down the road and if so what can you do to fix it, no kits fit without modification (4 link reasupension) because everything is designed to fit on the old "C" channel frame, and i haven't even started on the front suspension problems. You have to pre think everything out and it helps to have a friend help take all the measurements off the stock frame. For example. Distance from the front cab mount to the center of the front wheel and so on. I can keep going on and on.
Now no longer playing devils advocate. It is nice building your own frame because if you need to change anything you have the ability to do it. Plus it flows nice being all tube steel instead of have original frame and part tube steel (nothing against those who have backhalved there truck). It isn't too difficult if you take your time and plan things out. I did as much homework as i could prior to starting the frame. If you take careful measurments it and draw out all the angles it isn't too hard. Steel isn't too much i think i spent 400 building the base frame. The only thing that was really difficult was the front suspension but that is why i bought a weld in kit from Nathan with Porterbuilt street rods. If you do go this route i recommend saving your money and buying a kit from Nathan. Then you know that you will have the least amount of bumpsteer possible and all the control arms are in the correct spots for proper suspension. I just went through all this so if you do go this way i will give you as much advice as i can. Just think it through well so that way you don't waste any money and time. If you can fab and have access to the right tools I would say give it a try. If you realize that you can't do it or it gets too dificult you can say that you tried and you will only be out a few hundred dollars for the base frame plus your time. Hopefully i helped you out. Good luck.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 08-20-2007, 02:17 PM   #21
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks guys
I guess it's just up to me to figure out what I want to do
I have the stuff to build a frame & I'm pretty good when it comes to thinking everything through, I just don't know how nice or how much money I really want to put into my truck
The project is a little ways off, so that'll give me time to research & gather for the build
Sinister
Killer
