08-18-2007, 09:21 PM | #1 |
Active Member
SOLD! 4x4 Chassis - rolling ps pb bbc T350 $700.00
I have a mid 70's GM frame, front/rear axles,leaf springs, NP205 transfer case, Dana 44 front, 12 bolt rear, power steering box,power steering pump, power brakes (hydro boost), Turbo 350 with converter, big block chevy motor mounts, headers, 6 bolt wheels, disc brakes up front, drums in the back Everything appears to work correctly
I am selling this as a rolling chassis no engine no body $700.00 Thanks Bill
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
08-22-2007, 10:27 AM | #2 |
Active Member
Re: 4x4 Chassis - rolling ps pb bbc T350 $700.00
I will break the set up if anyone has an interest -the frame is shot(found out after we pulled the body off) so only the parts will do -
Shot me an offer
08-22-2007, 06:56 PM | #3 |
Junior Member
What type of rims are they?
68 SB 396 72 SB CHEYENNE 402 04 Silverado SS |
08-22-2007, 09:14 PM | #4 |
Active Member
The rims are old american racing chrome plated rusty rims - not worth much
08-26-2007, 09:31 PM | #5 |
Active Member
OK I did find that tag and confirmed that this is an NP205 Dated in late 1972
So it should be out of a 73 truck The rearend is dated 272 making it an early 72 rearend so it has most likley been swapped in, I am going to pull the covers and confirms insides and gears The hydro boost MC is gone so What I have left is Front Axle with Swaybar, Rear axle, leaf springs, PS box, PS booster, transfer case, T350 tranny, converter, NP205 adapter, 2 driveshafts and 4 shocks $450.00 you pick and pull. The body is off the chassis so it is easy to work on/ You can even take the entire roller if you want it
08-27-2007, 02:13 PM | #6 |
Luv the Crewcabs
Where are you located in Ohio, Would like to do Mapquest Search to see if i Could make the Trip??
Thanks, Rick Is This a LWB or Swb Frame? |
08-27-2007, 09:15 PM | #7 |
Active Member
Located just north of Columbus in Sunbury Ohio 186 miles from you
I am easy to get to 5 minutes off rt 71 I will have to put a tape measure on it for length - my gut tells me it looks like a swb, let me know \ Thanks Bill
08-28-2007, 07:15 PM | #8 |
Luv the Crewcabs
Do u Know if the Tranny is any Good? Could whole Thing be Pulled with a Tow Dolly? Any Overall Pics of the Frame? Did u measure it Yet?
Thanks, Rick |
08-29-2007, 09:56 AM | #9 |
Luv the Crewcabs
08-28-2007, 07:20 PM | #10 |
Rick,it looks like a good donor for the 1 ton wrecker build.I hope you get it.If you do,I may be interested in buying the sway bar and top spring plates for the swaybar,from you.....Heck,I could use the front driveshaft too.
Dustin Last edited by 1969k10stepside; 08-28-2007 at 07:21 PM. |
08-28-2007, 08:48 PM | #11 |
Why is the frame shot? Rust?
08-28-2007, 09:12 PM | #12 |
Active Member
Yes the frame is rusty - If you are interested let me know I am more interested in selling it than keeping it.
Thanks Bill
08-29-2007, 04:42 PM | #13 |
Active Member
Toomany - man so sorry I totally missed your request.
Yes it can be towed with a dolly. No I have not hit it with a tape measure Yes the tranny is good The truck last drove as a complete truck 8 days ago. I will grab a some addtional photos and post them tonight.
08-29-2007, 04:51 PM | #14 |
Luv the Crewcabs
Thanks, I would appreciate That. Im mainly interested in the Tranny & Transfer Case Combo for my Wrecker Project, However i would Take the Whole Thing To Make it Easier for Both of Us.
Only Reason ??? Length is for Driveshaft......... Thanks Again, Rick |
08-29-2007, 07:08 PM | #15 |
Active Member
Here are the pictures of the chassis.
I measured it and it is 116" which matchs my short bed truck. 116" center of hub to center of hub let me know what else you need.
08-29-2007, 08:53 PM | #16 |
Active Member
SOLD to TOMANYTOYZ
Thanks Bill
08-29-2007, 10:12 PM | #17 |
Luv the Crewcabs
Deposit sent via Paypal...............
Thanks again for the Deal on The Frame, Rick |
08-29-2007, 10:39 PM | #18 |
Congrats on the purchase Rick.Be safe when you go to pick it up
09-05-2007, 08:52 PM | #19 |
Luv the Crewcabs
Re: SOLD! 4x4 Chassis - rolling ps pb bbc T350 $700.00
Went & picked up the Frame Today, A Special Thank You To Bill & His Son Nick for All The Help with Loading. They also Did a Great Job of Having the Frame Ready For Hauling, Tranny was Braced, Driveshaft Disconnected & Ready To Roll.
Towed it About 200 Miles with no Problem, Again a Big Thank Guy's & It was a Pleasure To Meet You Both. Good Luck on Getting the New Motor in Your Truck Bill................ Thanks, Rick Bill & Nick Getting Frame Ready To Load............. Frame Loaded On THe Tow Dolly.................... Ready For Home............... |
