Old 08-19-2007, 11:45 AM   #1
low sierra
Old Time Rodder
low sierra's Avatar
longer wheel studs
couldn't find the thread but recently someone asked about longer wheel studs to use with rear disc conversion rotors. I just bought some from Napa part # 641-1578 which I installed on Friday and was pleased with the length. hope this info helps it you are converting to rear disc.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980)
Replacement cab had A/C which now works, made a real truck out of it
84 MC 305 350TH 3.08
4 wheel disc finally
My daily driver again
low sierra is offline   Reply With Quote
Old 08-19-2007, 05:48 PM   #2
Shane
Shane's Avatar
Re: longer wheel studs
thank you ... thank you ... thank you ...
Shane is offline   Reply With Quote
Old 05-01-2011, 12:22 PM   #3
dnd1978
dnd1978's Avatar
here is a little more info:
But the stud numbers I found were:
27883B Raybestos/ 610-258 Dorman/ 641-1578 NAPA Balkamp
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 05-01-2011, 06:55 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
When I did the c5 rear brake converison, I used the Dorman 610-298.
some spec on the Original stud:
Thread Knurl Dia. Length Shoulder
1/2"-20 .535" 1-17/32" 5/16"
spec on the 610-258 (mentioned above)
1/2"-20 .536" 1-23/32" 1/4"
spec on the 610-298:
1/2"-20 .547" 2" 11/16"
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
