Old 08-21-2007, 12:00 AM   #1
Purs
Got Big Block?
Purs's Avatar
Name these parts...
OK, I'm taking those first little baby steps on my project '69 K5. 1st step: clean out all the parts that were piled inside. Can you help me identify these parts?
1st pic: some interesting chrome rings, were they some kind of 2 piece wheel cover? Also in the first pic is I'm guessing some part of the transfer case or what??
2nd pic: there were 3 driveshafts. Why 3? Personally I like the candy stripe action.... I'm guessing the one with the disc on the end attaches to the transfer case?
thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 08-21-2007, 12:03 AM   #2
Purs
Got Big Block?
Purs's Avatar
Re: Name these parts...
2nd pic
Old 08-21-2007, 12:04 AM   #3
68caliRat
Need a bigger hammer..
The rings look like the are the tension rings from drums....The rest.. I only see 1 pic.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 08-21-2007, 12:06 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
The chrome rings are embroidery rings, the ones your wife has been looking for.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-21-2007, 12:10 AM   #5
69TowRig
The rightmost shaft looks like the rear, the striper doesn't belong, and the leftmost looks like the front but usually there isn't a companion flange, you'll have to look at yours to tell. Mine had a normal split yoke on the front output.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-21-2007, 12:20 AM   #6
Purs
Got Big Block?
Purs's Avatar
s/t
I Knew I couldn't get lucky enough to have some "ultra rare" 2 piece wheel covers that were worth a grand each......
thanks for the input guys. The engine is in the truck but the tranny and transfer case were in the back so I'm trying to put the puzzle back together.
thanks for the help.
Old 08-21-2007, 12:14 AM   #7
1969k10stepside
The one item in pic one is the "adapter" that goes between the tranny and transfer case.The driveshafts...the one on the right and middle are stock driveshafts.(the front one atleast,the back one may not be)The one on the left isn't.The striped is a rear driveshaft and right is the front.The far left looks like its a front d-shaft from a newer style 4wd (7? + )
1969k10stepside is offline   Reply With Quote
Old 08-21-2007, 12:17 AM   #8
71swb4x4
71swb4x4's Avatar
The chrome rings are from a snare drum. The one toward the top of the picture goes on the bottom of the drum, it has the slots for the snares to go through.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-21-2007, 01:11 AM   #9
eedgell
It's the air up here
eedgell's Avatar
Nice start for some sort of wild dream catcher... I think.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 08-21-2007, 07:51 AM   #10
Blazer1970
Blazer1970's Avatar
That t-case adapter is for a later model TH350/NP208 or 700R4/NP208 combo. The front shaft is also for a later model truck since it has the Saginaw double cardan joint (flange type) vs. the Spicer style that used a yoke on the t-case and was used on the '69 - '72 4X4s.
Blazer1970 is offline   Reply With Quote
Old 08-21-2007, 09:57 AM   #11
In the second picture,that`s a barber shop pole.
