08-24-2007, 07:38 PM | #1 |
Junior Member
Power steering box question?????
Guys I have a non power steering 67 swb pickup frame. I'm putting a quick ratio power steering box on from ecs. I was told to heat the frame and hammer dimple to fit new box. Looks like I need to dent frame quite a bit and maybe trim front body mount. I'm a little nervous to hammer frame that much.
Has anyone done this? Is this the right way? If so does anyone have pictures of this done or can someone take some and post. help thanks john |
08-24-2007, 07:49 PM | #2 |
member #16
Re: Power steering box question?????
Heres what it looks like.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-24-2007, 08:05 PM | #3 |
Junior Member
Thank you thank you thank you!!!! was it hard to move it that much?
08-24-2007, 10:04 PM | #4 |
The Older Generation
Everybody's mileage varies but I spaced mine out with spacers and new grade 8 bolts. No problems so far..... To me that's just as safe as heating the frame cherry red and beating a kink in it with a BFH. Just my 2¢ worth. LockDoc
08-24-2007, 10:18 PM | #5 | |
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-24-2007, 10:20 PM | #6 |
i would do it llike locdoc states, if it don`t work the way you like it, you can always beat on the frame, there is kits the you can buy with the spaces and bolts includes for this conversion, think the truck shop has them.
good luck..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
08-24-2007, 10:36 PM | #7 |
I used the washer method also and mine works great!
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
08-24-2007, 11:32 PM | #8 |
its all about the +6 inches
shimming it out can cause column bearing wear, it can cause the bolts to snap due to added leverage, esp if you are doing any off roading at all (I know you are talking about a 2 wheel drive though) it can also cause the gear box to be not centered and wear the gears faster, and if a variable rate gear, can cause twitchy steering a dead spot just off center.
08-25-2007, 12:19 AM | #9 |
A little heat and a medium "BFH" along with washer less than 1/16th thick should work just fine. I did mine with no heat and some washers back in 1993 and it is still fine after 40 to 50,000 miles. It is a '67 3/4T 2wd with a 454 and power disc brakes.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
08-26-2007, 09:26 AM | #10 |
Junior Member
Yeah I'm just about to send frame to powder coat, so this week I'll get the fire wrench and BFH out and dimple it . It also looks to me like the body mount in front of the box needs to be trimmed some too. Just a side note some of you guys say on your 67 frame's that the frame is flat where the box goes. Not mine the bolt holes are on raised pads 1/4" or a little more up..?
I don't know why or what it means, Any ideas??? |
08-26-2007, 08:52 PM | #11 | |
LockDoc
08-27-2007, 05:10 PM | #12 | |
NOT SURE EVERYONE CAUGHT THIS - would this not mean he doesn't have to dimple his frame as the raised bolt holes will push it out from the frame.... and would it also possibly mean it's not a 67 frame? Or are the raised areas there on the '67, just not out far enough? Have you actually tried to mount it yet?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
08-27-2007, 06:24 PM | #13 | |
Junior Member
Well for sure it is a 67 frame cuz my family bought it new. I have tried to mount it and it does not fit, it must be heated and hammered. The bolt holes are raised but for sure not enough. So here comes the HEAT!! |
08-26-2007, 10:44 PM | #14 |
I survived Dead Man's Curve.
I use spacers... no problems. I could understand freaking out if it was a 4x4 truck, but 2WDs? No bearings or anythign have goen out and all of these parts are used from the 'yard.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. |
08-27-2007, 02:04 PM | #15 |
mine was done by someone else with washers no problems so far the mod is old and still works but if I was to do it I would either notch and plate the frame or a little heat and a bfh, cause it does look kind of a git r dun mod
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
08-27-2007, 02:13 PM | #16 |
Java Mechanic
Is this just a 67 issue? I have a 68 C-20.. I just got a PS geer box from billsbowties but haven't even taken the old manual box off yet...
Just wondering if I need to prepare for this ...
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
08-27-2007, 03:22 PM | #17 |
As far as I know it is a one year problem - 1967. But I'm not sure about that. I think I'm gonna start with the spacers and go from there. I'm a little nervous pounding the crap out of an area on the frame that has been known to crack anyways. Besides, I don't think it would be a 5 minute deal - to get any kind of running start with the hammer you would have to take the outer and inner fenders off. Just my .02
08-27-2007, 03:47 PM | #18 |
I had to cut the rad support mount on both my 67 and 68... No spacers needed though.. Used a box for a 72 from advanced auto parts. Good luck!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
08-27-2007, 03:58 PM | #19 |
TOTY 2006
I heated up the section of frame on mine, and hammered it in. If you are going to spend a lot of time turning the wheels side to side while you are stopped, then yes, you may crack the frame. So far, I ahve only seen cracked frame in the 4x4s....
