Big gulps huh?
drainplug
well I was up under the truck today taking a look about how I am going to install this floor shifter. Anyways, I got a good look at this 3 speed tranny. And it appears to me that there is a drain plug in the center on the very bottom of the tranny. Seemed normal to me, and I figured I ought to look into the best way to change out the fluid inside. So I start snooping around these old threads trying to figure out what's involved in the fluid swap. Well from what I found, either people didn't have drain plugs, couldn't find them, or they were located on the side. Am I supposed to have a drain plug on the underside of the tranny? And what's the best way to effectively change the fluid? Thanks guys
When in Rome.. 1966 Chevy C10 Long Stepside: PROJECT TRUCK= custom cracked windshield, and uhh some sweet boat carpet 2000 GMC Sierra Short Wide: SHOW TRUCK= 22's, bags, performance engine, system, tv, blah blah blah 2004 VTX 1300C: DAILY DRIVER= Custom flame paint job, pipes, grips, mirrors, lights, pegs, etc etc ...2006 Honda Accord: OLD LADYS RIDE ![]() |
Re: drainplug
Yep. My 64 has draing plug on the bottom ond fill plug on the side (passenger side).
Swap fluids? Pull drain plug on bottom, let it empty. Put draig plug back. Pull fill plug from side, fill until it runs out the hole, put fill plug back. Done. To fill I use a plastic gear oil bottle that has the cone tip, Valvoline is the most recent I used. Work it around till the tip is in the hole, you'll only get the bottle to about level, it'll hit the cab floor or whatever. Squeeze out what you can, it'll maybe be 1/3 to 1/2 bottle. (I used a qt bottle.) If that wasn't enough, refill the bottle from the other bottle (oh yeah, get two, though you'll hardly need all the fluid from one). Repeat til fluid flows out the fill hole. |
Hollister, CA.
![]() Join Date: Sep 2006
Re: drainplug
My 3-speed is the same way..no plug...just remove one of the lower bolts and let drain.
Then fill thru the side. I use a pump-style w/ hose on the one galloon jugs.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Big gulps huh?
Re: drainplug
thanks for the reply guys. and what do you use? just 80 or 90W gear oil?
Hollister, CA.
Re: drainplug
yeap....
