Old 08-25-2007, 05:35 PM   #1
tx71smallblock
tx71smallblock's Avatar
module testing
i think i spelled it right?
is there a way to test an HEI module without going to the autoparts store?
wile im at it, i tryed to start the truck today and had no spark could the module be the only problem? the distributor, cap, rotor, wires and plugs are all new the only old part is the module.
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 08-25-2007, 06:51 PM   #2
BurnoutNova
BurnoutNova's Avatar
Re: module testing
the only correct way to diag an ignition module is to test eveything else... seems dumb, but those pos testers at the auto parts store just test continuity. sometimes modules will only act up at certain temps, and the parts store cannot recreate the same environment and bad modules will test good somtimes
BurnoutNova is offline   Reply With Quote
Old 08-25-2007, 06:59 PM   #3
tx71smallblock
Re: module testing
well i took it anyway and he said it was good and that it maybe the pickup coil. im not good at the electric part of the motor so i really dont know what that is.
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 08-25-2007, 09:04 PM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
Re: module testing
The pick up coil is on top of your distributor. Unbolt it and check continuity on the primary and secondary with an ohm meter.
http://67-72chevytrucks.com/vboard/s...ht=distributor
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 08-25-2007, 10:07 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: module testing
What I found in my HEI problem was the wire to the reluctor in the distributor was broken. It would make contact and when letting off of the gas, the vacuum advance would move and the wire connection would be broken. I fixed that problem with an Accel HEI replacement distributor. No problems since that time.
I can fix the old HEI with a new part from NAPA, but the whole distributor would need to be rebuilt...bushings, etc. It has a new 4-pin module in it and a nearly new Vette vacuum advance.
So, it may not be your module, as I found out....after replacing the distributor.
When you replace the module, if that is what it takes, be sure to use the dilectric grease in mounting the new part....that's what takes the heat away from the module. Without the grease, it just won't last.
Member Nr. 2770
Old 08-25-2007, 10:34 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Re: module testing
Also, check your dizzy cap to be sure that you have the metal ground that goes from the cap to the coil! I've seen it missing quite a few times. There should be two grounds in the cap. I fried a coil and module because I was missing one.
If your pretty sure it's your coil and module, I think coils are like $16 bucks and modules are about the same. Be sure to use dielectric grease on everything when you reinstall.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-26-2007, 12:04 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: module testing
If you care?
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
