Old 08-28-2007, 12:12 AM   #1
tubbed55
tubbed55's Avatar
IFS front
Been looking at IFS front ends in the magazines. I see they offer stock or 2" drop spindles. Is the stock the original truck height because it seems it will still be much lower then stock suspension? I want my truck lower in the front but not slammed.
tubbed55 is offline   Reply With Quote
Old 08-28-2007, 02:36 AM   #2
mr48chev
mr48chev's Avatar
Re: IFS front
Stock is the stock height for that particular spindle. With the 2-1/2 in dropped spindle the truck would sit 2-1/2 in lower w/o cutting the springs.
Probably the best thing would be to talk to the tech rep from the mfg you want to buy the cross member from and give info such as
I have this model of truck=
I want to run this tire and wheel combination=
I am going to run this engine and trans combination=
I want the truck to ride and sit at this height=
Then see what they suggest.
Old 08-28-2007, 09:00 AM   #3
jkaylor68gmc
jkaylor68gmc's Avatar
Re: IFS front
Yeah and I would recommend FatMan Fabrications, just got mine for the '52 last week, went coil-overs and 2.5 drop spindles. If you go coi-overs you can adjust ride height a little.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 09-03-2007, 02:40 PM   #4
solidaxel
solidaxel's Avatar
Re: IFS front
Another one for AD trucks is
Industrial Chassis Inc
These use a 86 to 90 Dodge Dakota bolt ons!
Lets try that again,
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-07-2007, 12:20 AM   #5
Dinos63
chevy only
Dinos63's Avatar
Re: IFS front
Steve does nice work
Dinos63 is offline   Reply With Quote
Old 09-07-2007, 12:29 AM   #6
Dinos63
chevy only
Dinos63's Avatar
Re: IFS front
What size tires and wheels are you going to run? you may think about that before you lower your truck. and how you want it to sit
Old 09-05-2007, 03:35 PM   #7
56chevy1300
56chevy1300's Avatar
Re: IFS front
I remember reading somewhere that an IFS will lower the truck 3-4 inches w/o lowered spindles.
56chevy1300 is offline   Reply With Quote
Old 09-05-2007, 06:13 PM   #8
solidaxel
solidaxel's Avatar
Re: IFS front
I guess a good measurment would be the center line of the spindel to the bottom of the frame at the spindel, with a solid axle and the Mll or any aftermarket IFS. They should be measured with the same height tires
LS 3 4L70E
Old 09-06-2007, 03:36 PM   #9
mylow53
mylow53's Avatar
Re: IFS front
heres an ifs with 2" drop spindels. i have arround a 1/4 inch clearance from the concrete to the oil pan. i think i could "lay" crossmember if i really wanted to....
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 09-07-2007, 02:58 AM   #10
68c10owner
68c10owner's Avatar
Re: IFS front
how much of a difference would you see if you used coil overs instead of a airbag set up? awsome truck by the way.
Anthony
68c10owner is offline   Reply With Quote
Old 09-07-2007, 02:07 PM   #11
mylow53
mylow53's Avatar
Re: IFS front
i'm just guessing the coil overs should be adjustable as well. they might have a bump stop lower than mine... the way the airbags are i can trim a 1/4" off the top of the bag mounting tube. the thing that bolts to the air bag then connects to your frame... and drop it futher... but as it is it's undrivable all the way down, so why try to damage the tranz or engine... thanks by the way
GT
Greg
Old 09-07-2007, 09:15 PM   #12
68c10owner
68c10owner's Avatar
Re: IFS front
GT
I guess I ment to say, how much higher would it sit with standard shocks and 2" spindles over the airbag set up? I installed a MII set up on my old 57 chevy pu and it dropped the front frame 13" from stock height without a motor in it. With stock spindles and a flip kit in the rear the cab was about my chest level and I`m 6' tall. I don`t know if the 47-55 frames would sit any different than my old 57. I`m still trying to get a old truck froma friend of mine,50-53?, and was wondering about the ride height. I like them low but not so low that you can`t drive them everyday and i`m not into the airbag set up.
Anthony
Old 09-30-2007, 10:45 PM   #13
twinturbo51
twinturbo51's Avatar
Re: IFS front
Thanks Anthony more the compliment. Think of the money I will save on polish!!
twinturbo51 is offline   Reply With Quote
Old 09-30-2007, 11:15 PM   #14
68c10owner
68c10owner's Avatar
Re: IFS front
yeah no kidding. I`ve been trying to get this old truck from a lder friend of mine. It`s a 47-53, not sure on the year, but it`s in a better shape than yours is but i wish it was in the same condition. Is that crazy or what? I love the patina look especially when it`s earned.
Anthony
Old 10-05-2007, 05:37 PM   #15
Bills_49
Broke Club =(
Re: IFS front
but when we are talking about these systems, which are the most user friendly? i have been looking around for a set up myself but i cant come to pick one. when i say user friendly i mean, easier to install.
Bills_49 is offline   Reply With Quote
Old 10-05-2007, 05:49 PM   #16
robin58
Re: IFS front
Easiest would probably be bolt-in from someone like RB's Auto. Other than that there pretty much all alike IMHO as far as ease of installation goes.
robin58 is offline   Reply With Quote
Old 10-07-2007, 01:42 AM   #17
BruceR&C
Re: IFS front
This is my wife's '47. Used a Fat Man Fab IFS w/stock spindles & took out 2 coils. Front bumper sits about 3 5/8" off the concrete. May go with coilovers to get a bit more hight out of it.
Cleverly disguised as a responsible adult
BruceR&C is offline   Reply With Quote
Old 10-16-2007, 04:15 PM   #18
Bills_49
Broke Club =(
Re: IFS front
i know its more money in the long run but, can u buy a crossmember then just add you're own upper and lower control arms? or is there a year of car where i can just get them and weld them to a mount? i dunno just checkin my options, havin a hard time findin a deal.
Old 10-16-2007, 06:20 PM   #19
BruceR&C
Re: IFS front
All the aftermarket manufacturers sell the crossmember seperately & you can either buy their hub-to-hub kit or use paieces from 74-78 Mustang II's. I did the hub-to-hub as I wanted to be able to not use the strut rod that the stock MII suspensions use.
Old 10-16-2007, 06:39 PM   #20
jplasse
Re: IFS front
there are deals out there... Keep hunting.. I picked up a new TCI mustang II kit brand new in bare steel for 800
jplasse is offline   Reply With Quote
