Old 08-29-2007, 07:23 AM   #1
k-20
sm465
can any one tell me if a sm465 box out of a 79' c20 would be the same as one out of a 79'k20.got a spare box out of c20,k20 box is getting noisey! transfer case is a np205,thanks
k-20 is offline   Reply With Quote
Old 08-29-2007, 11:27 AM   #2
Burt4x4
Burt4x4's Avatar
Re: sm465
Duno?
If the transfercase adapter can bolt to the 2x4 tranny then your good to go..if not well then your answer is no
I know no help right....I know nothing about 2x4 trucks....
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-29-2007, 12:31 PM   #3
earl87gta
earl87gta's Avatar
Re: sm465
the gear box may be the same but the tail shaft would be diffrent.
link to an artica on rebuilding them.
http://www.4wheeloffroad.com/brandpa...ild/index.html
Here are pics of the 2wd and a wd sorry not better but gives you an idea of the difrence.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 08-29-2007, 04:38 PM   #4
1969 GMC
1969 GMC's Avatar
Re: sm465
2wd SM465 have a 35 spline mainshaft with a threaded end for putting a yoke on the rear. 4wd SM465, depending on year, either have a 10 spline mainshaft with a sleeve to a male input transfer case, or a 32 spline mainshaft that feeds directly into a female transfer case input gear. Either way, you can't just swap the 2wd for the 4wd. You'll have to tear it down and rebuild it (which you would have to do for a mainshaft swap anyway) or run 'er until she blows
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-30-2007, 10:47 AM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
Re: sm465
Or you could go out and find a divorced version of a 205 (I'm thinking dodge, can't remember) and run it with the 2wd tranny. You'll need to have a short driveshaft between the trans and t/case and a totally separate t/case x-member. It's a lot of work, but you can end up with better driveline angles on the front shaft since it gets longer.
The easiest thing to do would be to rebuild your 4wd tranny.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 08-30-2007, 02:26 PM   #6
earl87gta
earl87gta's Avatar
Re: sm465
Thats how mine is getting set up I just have to finnish making the new crossmber for the 205 Im using a divorced 205 from a doge with a NV4500 2wd with paring break.
Earl
