08-29-2007, 02:17 PM | #1 |
3/4 ton rear end???
A friend of mine is doing some work on a 71 3/4 ton 4x4. He thinks the rear end is out of a 1 ton dually. He would like to put in the correct rear end. Will one owrk out of a 73-87 3/4 ton 2wd???
66 Acadian 2 door 69 GMC panel truck 78 Chevy crew cab dually 79 Chevy blazer 2wd 01 Chevy silverado 2wd reg cab shortbox |
08-29-2007, 02:32 PM | #2 |
Re: 3/4 ton rear end???
It probably is the original rear axle. I have a '72 3/4ton with a Dana 60 dually rear axle from the factory.
08-29-2007, 02:56 PM | #3 |
its all about the +6 inches
a DRW rear end is the same as a SRW.
08-29-2007, 04:36 PM | #4 |
I think the DRW rear ends are narrower due to different hubs. A 73 and up 3/4 ton axle will work, but you will need to move the spring perches. I forget how much, a search should turn it up. and a DRW rear dana 60? I want to see pics of this.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
