Active Member
BBC motor mount stand ?
I have a 68 that came with a 327. I bought 68-71 BB stands for a BB install. Was playing with the stands tonight and seems the frame at the top is 3/4-1"
to wide. My ? is do you need to trim or notch the frame for the BB stands? Thanks Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
Active Member
BBC engine stand ?
I have a ? and I tried engine & drivetrain and did a search. I have a 68 c-10 that came with a 327 so now it needs to have a BBC so I bought some 68-71 BBC stands. seems the frame is to wide at the top for the stands to fit, Do I need to notch the frame or something to make them fit? I looks like I need to take out about 3/4-1" to make them work.
Thanks Jack.
Re: BBC engine stand ?
How may of them beers did you have?? J/K, I 'm not sure but I thought this was a bolt on deal. I put the BB mounts on a 69' and it bolted right up.
Active Member
I thought it was a bolt on deal myself, Maybe a few more and they will bolt on. This truck is a 68 but maybe it has a 67 style frame and they are different? BTW I like my home brew but am out. need to brew again.
Jack
Living In The Past
I thought it was 67 only but maybe was 68 as well that you have to notch the frame for the BB stands. other years are bolt in
i just recently did the same in my 68, the early 68s and all 67s need to have the frame cut for the stands, you will probably have to also cut for the headers if you use them,
heres mine, you can see the cut around the header and for the mount.
Active Member
Thanks, The steering box seems to be OK, Maybe This frame is a mix of a couple of years?
Thanks Jack
Active Member
Lost wages,
What headers you running? Thanks Jack
Re: BBC motor mount stand ?
Yep
Active Member
Thanks!
67 is sold
Merged threads
I had to notch the left side for the stands and the headers (hooker p/n 2454), but the right side fit just fine, the headers did as well. I have a early 68 that came with a 6 cyl. I think they were using up left over parts when they built some these trucks. Here are some pics.
1968 Chevy shortbed fleetside Pro Street |
OK, now here are some pics, i hope
#15 |
Active Member
I guess maybe I should try my left side maybe it will fit.
Jack
