What is this bracket for?
What is this bracket for that is one the drivers side framerail? I want to remove it because I need to make a custom shock mount, but don't know what its for.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: What is this bracket for?
The z-bar for the clutch mounts to it........ I removed mine.....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Jul 2004
I agree, if you are running an automatic, it can be removed, that frame had a manual trans at one time, the auto frames never had that bracket installed.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
if i wanted to put a manual trans back in it, would i absolutely need that bracket or is there different options for the linkage?
sufficiently talented fool
![]() Join Date: Jun 2006
You would definately need that bracket for a clutch setup unless you converted to hydraulic.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
