Old 09-03-2007, 01:56 PM   #1
zacut
67 chevy SWB Fleetside
can't turn the key in the ignition
Looking for any advise. We own a 04 Avalanche. Last night we needed to move it back a few feet so my wife hopped in, turned the key, put it in neutral and let it roll back about 10 feet. She put it back in park, removed the key, got out and locked the door.
Today I hopped in and I can't turn the key. I tried the other key (both original and no luck). I can't find a blown fuse anywhere (thought maybe there was an electrical interlock) and I disconnected the battery for an hour hoping that might change things but no luck.
Anyone have any other ideas? Does the ignition have an electronic interlock that will stop the key from turning? Only 45,000 miles on the truck.
67 Chevy C10 Short Wide
350/350 ... Front Discs ... ECE Lowered 2.5/4
Vintage Air ... Oak Bed Floor ... Painless Wiring
Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake
Ididit Column ... VDO guages
zacut is offline   Reply With Quote
Old 09-03-2007, 02:22 PM   #2
smbrouss70
smbrouss70's Avatar
Re: can't turn the key in the ignition
Did you try turning the steering wheel one way or the other? If there is some tension on the steering wheel lock mechanism, then you can't turn the key. That would be my best guess.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-03-2007, 02:49 PM   #3
zacut
steering wheel lock is not engaged. I can turn the wheel from side to side.
Old 09-03-2007, 03:37 PM   #4
smbrouss70
smbrouss70's Avatar
As far as I know there is no electronic interlock on these trucks. I could be wrong though. Here are a couple of pages that I took from a complete wiring diagram that I got from AHDOL (Good deal for $12 IMHO) for my 04 Silverado. It doesn't show any type of interlocking system.
Can you move the shifter at all? Maybe it didn't go all the way back into Park before she removed the key? If not, then I think I'm stumped.
File Type: pdf Pages from 04_chevy_silverado-1500-5.3_complete.pdf (74.7 KB, 119 views)
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 09-03-2007, 05:20 PM   #5
zacut
thanks for the advise and the pages. Those do look handy. The shifter is in park. I can move it toward me, but not down and into any gear. I am stumped too. I hate to do it but I'll probably have to tow it to the dealer tomorrow.
Old 09-04-2007, 11:42 AM   #6
zacut
For anyone who is interested. . .
I found a gm mechanic on line who shared a service bulletin with me for 99-05 gm vehicles. It stated that the lock cylinders are prone to collecting enough of a dust build up to impede the pins from retracting correctly. The recommended solution was to shoot 60 psi of compressed air or brake cleaner in the lock cylinder to dislodge the material. It sounded far fetched after all I had tried but I gave some brake cleaner a shot and problem solved. I think I will remove the lock cylinder and clean it thoroughly and then oil it with some light oil.
Old 09-05-2007, 10:31 AM   #7
53burb
53burb's Avatar
GREAT info to know since I have a '99 Chevy 1/2ton. Thanks!!!!!!!!
53burb is offline   Reply With Quote
Old 09-05-2007, 09:10 PM   #8
Blue_71
Bloo
Blue_71's Avatar
just a word of warning zacut-- youll probably have to have the security relearned if you remove the cylinder. some of the do and some dont, im not positive on a 04 avalanche though
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
