![]() Join Date: Jul 2007
Finally got my new motor this weekend the numbers I can see are
rear drivers side 3970014 To the side of that looks like B 1 72 On the passengers side head 629930 Any help is appreciated this should be a 350 I pulled it out of an 80 GMC 1/2 ton just wanted to know exactly what I have. Thanks for the help Jeff |
Burnouts are therapeutic
Re: Sorry another engine id thread
according to nastyz28.com its a 70-73 350 2 or 4 bolt between 200-300 hp hope this helps.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
Fix It Till It's Broke
where on nasty z28 did you find that? here's my engine id numbers 3970010 and V0507CMR and 14J231718
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
semper I have same engine 69-79 350 or 68 327 probaly a 350 2 or 4 bolt main between 185 and 370 hp I did a yahoo search for nastyz28 small block engine casting codes -------- engine code breakdown is v=flint engine plant, 0507=may 7th, cmr=can be either 74 350 145 hp 2 bolt main or 78 350 220 hp 4 bolt main
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein Last edited by red69ss; 09-03-2007 at 03:34 PM. Reason: more info |
do you know what the numbers by the front of the pass side mean? the V0507CMR I know the V means flint plant...the 05 is may...the 07 is the 7th of may and what's the CMR?
just edited with answer
Where are the numbers you found on the pass side of the engine I can't seem to locate them
member #16
![]() Join Date: Dec 1999
This will show suffix code location and application.
http://www.nastyz28.com/chevy-engine-code-stampings.php
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
they are on the front pass side...kind of behind the alternator and alternator bracket...don't know if that helps I'll try and get a picture....
ksjh they are on a pad right in front of passenger side head probaly will have to clean there to see if engines dirty or sometimes these numbers get machined off if engine has been rebuilt all this engine code info comes from a website called mortec nastyz28 borrowed info from them thanks for adding link john
Thanks for the help found my info it was V0812TRJ that puts me at 175 hp Is that the total for the engine with factory exaust and th350 set or is that the long block only?
