My Big 10
Fairly new to the boards, new to posting anyways..
I haven't had this truck for long but I've done a fair bit of work to it in the short time I've had it. Picked it up after my first car got stolen (got when 16, I'm 19 now) from the people that live across the street. It had just been sitting there for a few months so we went over and talked, $300 later it was mine! 1979 Chevy Big 10. 350/SM465 4 speed The engine that was in it was pretty much done, 0psi compression in one cylinder and smoked really bad and fouled plugs real fast. Got a way healthier 350 from my stepdad for free and put it in! Here are some pictures: when I first got it ![]() ![]() cleaning the "new" engine up ![]() ![]() ![]() dirty old engine bay ![]() ![]() powerwashed engine bay, a lot cleaner now ![]() engine ready to go in! modified the wire looms to go upwards instead of stick out ![]() ![]() |
Re: My Big 10
in and running!
![]() ![]() then I got bored and decided it needed some scallops! ![]() ![]() So far I've got well under $500 in it and it runs very good now, short of needing the carb rebuilt and a few little tweaks here and there that still need addressing. I think it will be a fun truck, and I'd like to lower it slightly some day but I'm in no rush. Manual transmissions are fun, but not so much this one. The new motor has a bit of a cam and some other things done (I'm not sure what, really) but it hauls pretty good in first, but the RPM drop into second is horrible so I can't really get it goin' too quick. We've got a TH400 around, maybe some day I'll swap it in. Thanks for looking! |
On a budget like Fred Sanford
Re: My Big 10
Great progress so far! Get rid of that old sm465 & stick a car 4 speed (muncie, T10) in it's place. You'll grin from ear to ear.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 09-06-2007 at 03:26 PM. |
#4 | |
Re: My Big 10
I wish it was a turbo regal! It's an '87 regal limited with an olds 455. It's pretty fun |
Re: My Big 10
I didn't have to modify/relocate my stock crossmember or driveshaft. You can use the truck bellhousing with a car 4 speed, but you must use an adapter ring for the input bearing retainer since the truck bells are bigger. If you want more info, pm me and I'll show you where to get the adapter. I don't remember what the input shaft spline count is on a sm465, so I can't answer the clutch question for sure. My m21 is a 10 spline, but some were 26 spline. As long as they're the same between the two trannys you have, you can reuse the clutch.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Re: My Big 10
I agree, get a car 4 speed for it.
Right turn Clyde
Re: My Big 10
Got anymore pictures of the choke setup on the carb?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Re: My Big 10
Right turn Clyde
Re: My Big 10
Im not sure but it looks like the one I just picked up. It looks a little odd to me.
Re: My Big 10
As requested:
![]() ![]() ![]() Blocked off vac line goes to the thing in the air cleaner snorkel. http://i135.photobucket.com/albums/q..._1278Large.jpg http://i135.photobucket.com/albums/q..._1277Large.jpg http://i135.photobucket.com/albums/q..._1275Large.jpg I can also email you the fullsize ones if you desire. Last edited by oldpurple; 09-06-2007 at 07:03 PM. |
The Crazy Machanic
Re: My Big 10
looks good
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Real Projects never die
Re: My Big 10
his carb setup is no longer correct for a big ten, if anyone needs any info on big tens especially the correct style carb i have about 10 of them off different trucks and my dad knows as much as he can find out about them. I have two 77 big tens.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
#13 | |
Re: My Big 10
No? ![]() It's just the one that came on the truck when I bought it. |
![]() Join Date: Jul 2003
Re: My Big 10
I have to disagree with you there, that choke style is exactly like the one on my 78 big ten, and my 78 k-10. It is correct for a heavy duty federal emissions truck. My truck until I had to rebuild it had never been apart and it is a numbers matching engine and truck.
#15 |
Re: My Big 10
17058213
The carb number, say's its for a '79 with a manual trans. I'm not really sure what you mean by it's wrong? Carb # Application 17058213 CHEV 78 GMC HD Truck & '79 Canada HD |
#16 |
Re: My Big 10
Looks great! Its neat to make a go of it on a budget. I've got a '78 Big 10 just waiting for a motor.
#17 |
Re: My Big 10
AH, sorry, i thought you had an electric choke on there, thats what i thought i saw. Thats the right carb setup, excuse my comment. It seems i need to get my eyeballs checked haha
#18 |
Re: My Big 10
#19 |
Re: My Big 10
thats a good lookin truck for that price
Just remember just cause somethings on canadian built trucks are different then the usa built one it does no mean it is not right or stock. There were several canadian only vehicles that gm made.Pontiac beaumounts(chevelle spin off)(s/p?)pontiac Acadians(chevy 2 and chevette spin off),and the ventura's(yearly 70s nova spin off) pontiac Astre (here they started in 73 and shipped to the states for 75-77) There was also some candian only trucks.1976 some gmc serria grandes were called "oylmpic edtion "white truck with olympic rings in red on the rear quarters,hood emblem was also the oylmpic rings.INERTIORS were all red inside. we also had the wrangler trucks that had a two-tone paint and special stripping on them. GM was not the only for the big three to do this.Ford made the mercury trucks,mercury monarchs,and the Alberta edition ford pickups(there was one other ford car in the late 50sor early 60s as well.Dodge had the fargo pickups but there car line the dodge monacos (also in the usa)but the canadian made ones had a total different body style to them. other canadian only make that no longer exist.frontiac ,durant/star(yes William durant moved north arfter starting chevrolet and gmc and getting the boot from the companys.Studebaker lasted two years longer in canada first two are a 68 beaumont 60s acaidan venturas wrangler pick up(more color combos then brown just the best pic i could find) |
#20 |
Re: My Big 10
I know its a ford but here is a pic of a 57 mercury truck
merc truck were made from 41-68 here |
#21 |
Re: My Big 10
Well I picked up a carb kit tonight so probably tomorrow I'll take it off and get it soaking, should be 10x better with a carb that works well.
#22 |
Right turn Clyde
Re: My Big 10
Thanks for the pictures but is that a different carb? I was talking about this one.
It looks like a hot air choke I think. ![]()
#23 |
Re: My Big 10
thats a different carb, that must of been the one i saw, i knew i wasnt wrong.
#24 | |
Re: My Big 10
I was wondering how you could even see the carb, but I forgot about that picture. Yes that is a hot air choke one, I didn't use it. I used the one that was on the truck. That one was wrong for my intake anyways, nowhere for the tubes to go. Sorry about that! I don't know how those kind of carbs are setup for choke, but I believe you can convert them to electric choke easy enough and get rid of some clutter. |
