09-06-2007, 04:20 PM | #1 |
72 Cab replacement ?
My dad gave me his 1972 Chevy pick-up after owning it for 20 years. The cab is pretty much a rust bucket. What years of truck cabs would fit?
09-06-2007, 04:30 PM | #2 |
Official Site Guitar Shredder
Re: 72 Cab replacement ?
all 67 through 72.
09-06-2007, 04:35 PM | #3 |
member #16
A 71-72 with a cable throttle would be a direct bolt on. The 67-70 trucks have a throttle rod, but can be changed with a little work on the firewall.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
09-06-2007, 04:50 PM | #4 |
If you want it to look 100% a '72 is what you need, as it has the proper cable throttle and no provision for mounting the mirror on the roof like a '71 would have.
"You can take the man out of PA, but you can't take PA out of the man" |
09-06-2007, 06:25 PM | #5 |
Always on the hunt...
JMO, go with another 72 cab, they are plentiful and easy enough to find. Also to add to the above, I have found that the firewall provisions for mounting the under dash fuse panels/wiring are different on the earlier cabs. Cb
09-06-2007, 04:49 PM | #6 |
More Cowbell....
That conversion John mentioned can be done like this (or you can weld in the proper sections)...
No-weld throttle conversion
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
09-06-2007, 07:16 PM | #7 |
Cool, thanks guys!!!
09-06-2007, 07:29 PM | #8 |
and don't forget the vent in the door jamb on the 72s only not that it matters
common sense isn't so common anymore |
09-07-2007, 10:57 AM | #9 |
Next project: 1970 K10
And the e-brake differences; handle -vs- foot brake. The upper left firewall area is totally different between the two.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-22-2007, 03:00 PM | #10 |
Not to hijack the thread but.... Will a brake and clutch pedal assembly from a 67 fit into a 72 cab? Are the firewalls or distance to dash different?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
