Junior Member
Tublar A-Arms???
what benefit's are there to tubular A-arms?? Please let me know, thanks.
(other than looks?? ) Sorry bout the spellin LOL
going to sell this one...looking for a SWB project next. Last edited by Jcentsr6; 09-08-2007 at 07:17 PM. |
Re: Tublar A-Arms???
ART advertise better geometry on their arms..... not sure about other brands.
Junior Member
better geometry.....Means?? In the real world?
going to sell this one...looking for a SWB project next. |
![]() Join Date: Aug 2006
With the strong arms (ART) they change the mounting angle of the ball joint to help it from binding up for lowered trucks. It is only a few degrees but it is supposed to make a difference. I would imagine that most of the companies that make aftermarket control arms would do the same thing. Besides the tubular A-Arms just look alot better!!!!
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold Last edited by abadsvt; 09-08-2007 at 08:28 PM. |
It'd be alot cooler if you did
on my truck, it's the difference between the control arms scraping on te ground and them not. It's also the difference between the uppers hitting the frame and not. plus they look cooler.
i have the air ride strong arms on my truck, for a lowered truck they added in positive camber (less shims to align the front) and more caster (less bump steer), the ball joint angle is lessened also. the only downside to the strong arms is you have to use air ride techs sway bar.
