Old 09-09-2007, 11:02 PM   #1
oldsub72
oldsub72's Avatar
1947 and up 6 lug GM bolt patterns
Just wondering if the 6 lug GM bolt patten is the same on 47 and up. Specificly 47-70. Thanks
RED
oldsub72 is offline   Reply With Quote
Old 09-09-2007, 11:35 PM   #2
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
Re: 1947 and up 6 lug GM bolt patterns
basicly all 6 lugs are the same even the Jap junk w/fit it, BUT if you get into the late 80's & up the offset is different. BUT a none disc brake rim won't work on a disc brake set up...joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 09-10-2007, 03:09 PM   #3
northerngmc
northerngmc's Avatar
Most 6 bolt patterns are the same. The only exception I know of is the newer Dodge Dakota's, they are 6 bolt but a smaller pattern.
The bolt pattern is the same on a 47 and an 07, but there are other issues such as backspacing and the centre hole diameter to worry about.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-15-2007, 12:10 PM   #4
sweet70beast
sweet70beast's Avatar
We tried to put wheels and tires from a 04 on my bro-in-laws 69 and not only is the center hole a different size the bolt holes were a different spacing not a lot but just enough that it wouldn't work even if we made the center hole bigger. The wheels I have on my 50 started on a 68 then went to an 83 then to my 50.
sweet70beast is offline   Reply With Quote
Old 09-17-2007, 11:42 AM   #5
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i just put some newer wheels from a gmc truck on my parts truck. the lug spacing is the same. i couldn't get the front ones on though, the hub center on the 55 is 3.5" and the wheels are 3" i am going to either bore the wheel out or turn down the hub.
i would rather turn down the hub, so the truck can fit any late model wheel, but how thick is that hub? will it get too thin if i take 0.25" off?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
