Old 09-10-2007, 12:16 AM   #1
CJ5 Convert
CJ5 Convert's Avatar
Help - NP205 Ratio adaper.
Hey I posted this in the truck thread cause it has a lot of traffic but I need help on this one. If someone doesn't mind looking. Ok I figured out it's called a ratio adapter. I messed this one upgood.
http://www.67-72chevytrucks.com/vboa...d.php?t=257679
Thanks Jason
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
CJ5 Convert is offline   Reply With Quote
Old 09-10-2007, 10:52 PM   #2
old man jimmy
Re: Help - NP205 to Speedo Canle thingy
Mine came with one of those when new also. But after I went to some bigger tires my spedo was really showing slow. Did away with it, and changed spedo gear. Just put your cable where it was, and check to see if your speedo is off. If not, you don't need it.
old man jimmy is offline   Reply With Quote
Old 09-11-2007, 01:24 AM   #3
CJ5 Convert
Thanks OldmanJimmy
- Jason
Old 09-11-2007, 10:53 PM   #4
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Hello CJConvert.
Here is a pic of the one on the 205 in my 70 Jimmy. As you can tell it looks quite different than the one in your pic, and mine has a zerk for greasin' it up.
I'm just gonna clean it up and use it again. OldManJimmy's solution seems like it should work just fine.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 09-12-2007, 02:27 AM   #5
CJ5 Convert
Originally Posted by 70gmcjimmy View Post
Hello CJConvert.
Later---DAC
Thanks I need all the help I can get now if I could just figure out how the tire size and rear end ratios affect everything else. I'd be good.
- Jason
Old 09-12-2007, 04:25 AM   #6
old man jimmy
It's pretty simple. Taller tires act like taller gears. If you have the size tires on it you plan to run. Just take it on a highway with mile markers, and see what your odometer reads (1/10s that is) and what it read when you get to the next marker. If you loose 1/10th in a mile. your speedo is 10% slow. As an example. If your speedo shows 60mph + 10%, you're really going 66mph. Going back 35 yrs. But I think 1 tooth on speedo gear is about equal to 10%. Only trouble you don't have the nylon (inexpensive) gears. You have a real nice machined steel one, that is probably pretty hight bucks by now.
Old 09-12-2007, 07:04 AM   #7
ericguy320
I went from 3.08 to 3.73 with 33" and my speedo was off 15mph at 60, removed that box and now its only off .3mph at 60.
http://community.webshots.com/user/ericguy320
1972 Chevy C10 SOLD
1972 k5 blazer cst 350, sm465, rust
1993 gmc Typhoon for sale $13,900 obo
1980 Ironhead Sportster
ericguy320 is offline   Reply With Quote
