Old 09-11-2007, 01:13 PM   #1
Goodie
Goodie's Avatar
Heater Core replacement
Ok fellas it looks like I'm going to drive my Siverado when it gets cold, so I'm going to replace the heater core...
I have a few questions... I've replaced one in my mini truck
Will I have to remove the Dash?
Will I need to remove the air conditiner box in the engine compartment
Do I need to remove the fender?
let me know guys...
thanks
Goodie is offline   Reply With Quote
Old 09-11-2007, 01:32 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Heater Core replacement
No
yes
no
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 09-11-2007, 01:39 PM   #3
Goodie
Goodie's Avatar
how many hours???
Old 09-12-2007, 08:33 PM   #4
75shortysocal
350+dual flows= fun :)
75shortysocal's Avatar
Originally Posted by Goodie View Post
how many hours???
6 hours...
lol... j/k..
i pulled mine out, re-saudered the broken tube, and put it back in, took about an hour.
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!!
SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!!
75shortysocal is offline   Reply With Quote
Old 09-12-2007, 11:19 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Originally Posted by 75shortysocal View Post
6 hours...
lol... j/k..
The 6 hour thing is the redneck way---remove a bolt, Drink beer, remove a heater hose, Drink more beer, remove the housing, drink a lot of beer, remove the core, Forgot where the beer is--went to buy more--couldn't find the store---GAVE UP....
Old 09-12-2007, 11:51 PM   #6
bigblock79
67 Chevy Stepside
bigblock79's Avatar
lol 2 hour max
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 09-13-2007, 12:24 AM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Originally Posted by bigblock79 View Post
lol 2 hour max
I would plan for 6 hours if i was doing it. That's a doofus factor of 3...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-11-2007, 02:23 PM   #8
Eyegore
What Hump?
Eyegore's Avatar
Depends on what your going to do with the freon, are you going to recharge, then you'll need to evacuate the system. But the overall replacement of the heater core, perhaps 2-3 hours depending on your skill level, mine being zero.
Lil red 86 c-10
99 Sub
Old 09-11-2007, 03:23 PM   #9
Goodie
Goodie's Avatar
Ok eyegore my unit air conditioner unit is disconnected...so just remove that and I should be able to get to the core??? it took me like 6hrs to do the one in my isuzu... I had to remove the dash take apart the heater box just a cluster F@#k
Old 09-11-2007, 04:53 PM   #10
C&C Chevy
C&C Chevy's Avatar
Don't forget to disconnect your heater hoses, and put an old towel down before you remove it.
http://www.coloradok5.com/heatercore.shtml
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 09-11-2007, 05:04 PM   #11
piecesparts
In most cases the replacement of the heater core on a truck like yours---don't know your exact year, but in an 81 to 87---the heater housing inside the truck and the glovebox need to come out. The outside A/C housing does NOT need to be moved what so ever. You will need to go to the outside and take some nuts off of the bolts that stick through the firewall and you will have to take some screws out of the inside of the cab (all of which hold the housing in place). Once done, disconnect the heater hoses in the engine compartment, disconnect the heater controls and the vacuum hose (Mark everything). Then with the glovebox gone, roll out the heater housing and that will let you get to the heater core holding straps. Take the core out and put in a new one. Now re-install in a reverse fashion.
Old 09-11-2007, 06:34 PM   #12
Eyegore
What Hump?
Eyegore's Avatar
Really,then i must have done it wrong on my 86 and 78. Did them both through the engine compartment, loosened the nuts that came through the firewall and pulled the box off, split the a/c box removed the evaporator then the heater coil, don't ever recall doing anything under the dash except putting a wrench on to back the nuts off the other side.
Lil red 86 c-10
99 Sub
Old 09-11-2007, 07:31 PM   #13
piecesparts
Having had to work at a poor backwater county road maintenance shop (not to mention the fact that my son's truck and mine both have had to have new cores), I got the chance to learn this fact the hard way. The whole core housing can be laid on the work bench and the core removed at ease. The last one that I did, took me a whole sum total of 2 hours to go from system filled with antifreeze back to system filled with antifreeze and working.
Old 09-12-2007, 06:35 AM   #14
Goodie
Goodie's Avatar
I've read something like that shortly after I noticed my heat core went bad... I wasn't planning on driving it in the cold so I just by passed the core now I will be... I'm thinking about 3 hrs for me then...
Old 09-12-2007, 06:37 AM   #15
Goodie
Goodie's Avatar
Oh yeah its a 86
Old 09-12-2007, 11:59 AM   #16
jdmaffeo
jdmaffeo's Avatar
I just did my 84 2 weeks ago and it took right at 2 hours. It was all done like piecesparts said. There were I think 3 or 4 bolts by the a/c box in the engin compartment and the rest was all under the dash. Take your time and you will be supprised how easy it is!
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop.
jdmaffeo is offline   Reply With Quote
Old 09-13-2007, 01:14 AM   #17
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Here's a tip - after installing the new core, when you hook up the supply hose from the engine's intake slip some kind of flow restrictor in it just before the core - it will reduce the pressure so when you revv the engine up you won't be trying to balloon the core. Did that to my car, no core blown yet, and I do go WOT every so often and them cores are know to blow easily. Did it to the truck too after blowing core while engine break-in, never had any problems ever. For a restrictor I used like three 7/16 washers stacked on top of each other, but you can use some kind of brass bushing or something else suitable that you find rolling around in yer garage.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 09-14-2007, 06:12 PM   #18
piecesparts
Interesting approach, I have never had that issue, to speak of. The restrictor is not a bad idea UNLESS you have a cold winter in your area.
Old 09-13-2007, 06:35 AM   #19
Goodie
Goodie's Avatar
Right on... I will do it sometime this weekend.. I will probably will change all the hoses and thermostat too...
Old 09-13-2007, 08:24 PM   #20
Ivan D.
Ivan D.'s Avatar
Yes, that's always a good idea. Actually I have to change thermostat too, I run 160F now cause I got a small radiator and no shroud, but now that it's getting colder I think I'm gonna go up to 193F and throw a shroud in there.
Old 09-14-2007, 07:29 PM   #21
Ivan D.
Ivan D.'s Avatar
Just ask some of yer local Mustang guys, or anyone else who got a 302 that don't spend its live under 2000 rpms - maybe it's the pumps Ford put in those things, but they are known to blow heater cores during high revv, to the point where Ford actually put a restrictor in there. And oddly enough installing a restrictor doesn't reduce heater core output, but just the opposite - I know it don't really make a whole lot of sense, but that's what I observed in both the car and the truck. Now, blowing the core in my truck may be contributed to it being old, and our truck cores may be generally much tougher than the Ford ones, but it never hurts giving the restrictor a shot.
Old 09-14-2007, 08:13 PM   #22
piecesparts
The idea of a restrictor in a line with hot water in it is a good idea for slowing down the flow to get more heat transfer for each drop of water. The average exchange for a heat exchanger without a restriction that is around 16 degrees across the pipe wall. The restrictor on the inlet side is good for removing surges in the system, and slowing the water down will give more exchange, but it will have limitations.
Ford is not stupid---they just don't how to spell GM.
Old 09-14-2007, 09:56 PM   #23
Ivan D.
Ivan D.'s Avatar
Figured it's something like that, slow water means more time for the water to spend in the core, and more time in the core means more time to dissipate heat, right?
Old 09-16-2007, 07:58 PM   #24
Goodie
Goodie's Avatar
well bros thanks alot it was a bit more difficult...probably because of the make...and year... I had to take the damn heater box out and I had to take the screws out of the air conditioner in the front some of the screws was a biotch but i got them... I dropped the inner fender well and that made it easier... I was hoping it was simple like some of you guys said... I put new heater hoses on and I put a new starter on too...damn thing was going out so I did that too... heat is working fine... didn't tighten one of my hose like a dumb ass but its all good now... this site is awesome thanks!!!
Old 09-16-2007, 08:01 PM   #25
piecesparts
Holy Cow---after all that and you still like us?
