drag it like you stole it
panhard rod?
who sells an adjustable panhard rod?
negative camber //LA\\ |
I Love This Stuff!
www.earlyclassic.com sells good stuff, aswell as most of the companies on the main page
My Rides 1967 C10 In Pieces for now ![]() 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
![]() Join Date: Sep 2001
Second that. They have a great adjustable rear traction bar that allows you to change the geometry of your rear-end in case you want to drop it. It goes from the frame at the stock location all the way to a bracket they send you that goes under the passenger side saddle on the rear axle housing. I'll be grabbing that when I do the rear drop.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
chevelito
custom classic perform also has one.
classicperform.com
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
chevelito
classicperform.com
i dont really understand the concept of this banhard rod thing.. i think it is suppose to keep your rearend centered? what happens if you have an adjustable suspension such as airbags? wouldn't it move then?
#7 | |
Seņor Member
There are a number of other effects the triangulated rear suspension have, but I suspect they would probably bore most of you and/or aren't really relevant since you're not doing circle track racing. Here's a link for everything you ever wanted to know about triangulated rear suspensions but were afraid to ask. ![]() BTW, four-link rear suspensions don't have this problem! (they have others, but this ain't one of them)... Kenneth
so should i get a 27" or 24" adjustable?
#9 | |
Seņor Member
What you'll do is adjust the spherical rod end until the rearend is centered when the truck is lowest. That way the tires will be most centered when they have to contend with clearances of the inner and outer bed walls (or rear fenders on stepsides). When the truck is raised to the driving height, the rearend will be offset to the left slightly, but you'll be hard pressed to notice it, and the sheetmetal clearance won't be much of a problem since your tires will actually be below instead of beside the bed walls. Kenneth
they say you don't need one with a 4" drop but i HIGHLY reccommend it. before i changed when it shifted hard the truck would kick to the left. it wasn't a very safe situation.
68 short step, 406/700r4, 9" w/discs. |
