09-15-2007, 02:28 PM | #1 |
summit gas tank install question
I am going to move my rear crossmember back a couple inches on my 55 chevy truck so the tank will sit in nicely.
My question is this...the rear crossmember shares a couple rivits with the bottom of the rear leaf spring shackle mount. Can i just relieve the pressure off the leafs, grind out he rivits, replace the rivits on the rear leaf with grade 8 bolts/nuts and call it good? seems like it would be fine to me but I am just making sure.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
09-15-2007, 03:31 PM | #2 |
Yellow truck club
Re: summit gas tank install question
Hey
I just cut the rivets out with the grinder and replaced with the bolts. I didn't worry about the springs. Nothing seemed to move. Setting the tank up this way also help the filler hole clear one of the under bed cross members also. Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
09-15-2007, 09:36 PM | #3 |
i just put mine in today , i moved the Xmember back so that the front holes in it lined up w/the rear holes in the shackel mount , that way it gives you a perfect sized opening.
09-15-2007, 09:54 PM | #4 |
Yellow truck club
Less holes to drill too!!
Brian ...
09-16-2007, 12:37 AM | #5 |
that is important for me. I HATE drilling. I have had the drill grab as it goes through and vroom it is out of my hand. scares the snot out of me.
09-18-2007, 02:15 PM | #6 |
I did a similarmod to my 54 but left the spring mounts as they were and boxed in the frame about 8 inches in that area so the structural integrity would not be affected.
Later I ended up boxing in the entire frame since I had the material and time. The crossmember ties in the spring mounts to the frame so something should be done to strengthen them if you move the crossmember. |
